[mapserver-users] Access to a remote raster file in wms-mapfile
David Alda Fernandez de Lezea
dalda at ikt.es
Thu Feb 4 02:39:49 EST 2010
Thanks for your answers:
Daniel: I tried what you mentioned:
1- Does "gdalinfo --formats" list the ECW format?
Yes it does.
Supported Formats:
VRT (rw+): Virtual Raster
GTiff (rw+): GeoTIFF
NITF (rw+): National Imagery Transmission Format
RPFTOC (ro): Raster Product Format TOC format
HFA (rw+): Erdas Imagine Images (.img)
SAR_CEOS (ro): CEOS SAR Image
CEOS (ro): CEOS Image
JAXAPALSAR (ro): JAXA PALSAR Product Reader (Level 1.1/1.5)
GFF (ro): Ground-based SAR Applications Testbed File Format (.gff)
ELAS (rw+): ELAS
AIG (ro): Arc/Info Binary Grid
AAIGrid (rw): Arc/Info ASCII Grid
SDTS (ro): SDTS Raster
DTED (rw): DTED Elevation Raster
PNG (rw): Portable Network Graphics
JPEG (rw): JPEG JFIF
MEM (rw+): In Memory Raster
JDEM (ro): Japanese DEM (.mem)
GIF (rw): Graphics Interchange Format (.gif)
ESAT (ro): Envisat Image Format
FITS (rw+): Flexible Image Transport System
BSB (ro): Maptech BSB Nautical Charts
XPM (rw): X11 PixMap Format
BMP (rw+): MS Windows Device Independent Bitmap
DIMAP (ro): SPOT DIMAP
AirSAR (ro): AirSAR Polarimetric Image
RS2 (ro): RadarSat 2 XML Product
PCIDSK (rw+): PCIDSK Database File
PCRaster (rw): PCRaster Raster File
ILWIS (rw+): ILWIS Raster Map
SGI (rw+): SGI Image File Format 1.0
SRTMHGT (rw): SRTMHGT File Format
Leveller (rw+): Leveller heightfield
Terragen (rw+): Terragen heightfield
GMT (rw): GMT NetCDF Grid Format
netCDF (rw): Network Common Data Format
ISIS3 (ro): USGS Astrogeology ISIS cube (Version 3)
ISIS2 (ro): USGS Astrogeology ISIS cube (Version 2)
PDS (ro): NASA Planetary Data System
ERS (rw+): ERMapper .ers Labelled
ECW (rw): ERMapper Compressed Wavelets
JP2ECW (rw+): ERMapper JPEG2000
L1B (ro): NOAA Polar Orbiter Level 1b Data Set
FIT (rw): FIT Image
GRIB (ro): GRIdded Binary (.grb)
MrSID (ro): Multi-resolution Seamless Image Database (MrSID)
JP2MrSID (ro): MrSID JPEG2000
RMF (rw+): Raster Matrix Format
WCS (ro): OGC Web Coverage Service
WMS (ro): OGC Web Map Service
MSGN (ro): EUMETSAT Archive native (.nat)
RST (rw+): Idrisi Raster A.1
INGR (rw+): Intergraph Raster
GSAG (rw): Golden Software ASCII Grid (.grd)
GSBG (rw+): Golden Software Binary Grid (.grd)
GS7BG (ro): Golden Software 7 Binary Grid (.grd)
COSAR (ro): COSAR Annotated Binary Matrix (TerraSAR-X)
TSX (ro): TerraSAR-X Product
COASP (ro): DRDC COASP SAR Processor Raster
PNM (rw+): Portable Pixmap Format (netpbm)
DOQ1 (ro): USGS DOQ (Old Style)
DOQ2 (ro): USGS DOQ (New Style)
ENVI (rw+): ENVI .hdr Labelled
EHdr (rw+): ESRI .hdr Labelled
GenBin (ro): Generic Binary (.hdr Labelled)
PAux (rw+): PCI .aux Labelled
MFF (rw+): Vexcel MFF Raster
MFF2 (rw+): Vexcel MFF2 (HKV) Raster
FujiBAS (ro): Fuji BAS Scanner Image
GSC (ro): GSC Geogrid
FAST (ro): EOSAT FAST Format
BT (rw+): VTP .bt (Binary Terrain) 1.3 Format
LAN (ro): Erdas .LAN/.GIS
CPG (ro): Convair PolGASP
IDA (rw+): Image Data and Analysis
NDF (ro): NLAPS Data Format
EIR (ro): Erdas Imagine Raw
DIPEx (ro): DIPEx
LCP (ro): FARSITE v.4 Landscape File (.lcp)
RIK (ro): Swedish Grid RIK (.rik)
USGSDEM (rw): USGS Optional ASCII DEM (and CDED)
GXF (ro): GeoSoft Grid Exchange Format
HTTP (ro): HTTP Fetching Wrapper
HDF5 (ro): Hierarchical Data Format Release 5
HDF5Image (ro): HDF5 Dataset
ADRG (rw+): ARC Digitized Raster Graphics
BLX (rw): Magellan topo (.blx)
2- Check that you are able to open the file with
gdalinfo \\192.168.1.4\ortofotos\EUSKADI_2009_ED50.ecw
I'm able to get file info:
Driver: ECW/ERMapper Compressed Wavelets
Files: \\192.168.1.4\ortofotos\EUSKADI_2009_ED50.ecw
Size is 596353, 462680
Coordinate System is `'
Origin = (457707.500000000000000,4811974.969999999700000)
Pixel Size = (0.250000000000000,-0.250000000000000)
Corner Coordinates:
Upper Left ( 457707.500, 4811974.970)
Lower Left ( 457707.500, 4696304.970)
Upper Right ( 606795.750, 4811974.970)
Lower Right ( 606795.750, 4696304.970)
Center ( 532251.625, 4754139.970)
Band 1 Block=596353x1 Type=Byte, ColorInterp=Red
Overviews: arbitrary
Metadata:
LAYER_TYPE=athematic
Band 2 Block=596353x1 Type=Byte, ColorInterp=Green
Metadata:
Band 3 Block=596353x1 Type=Byte, ColorInterp=Blue
Metadata:
Jukka:
I've got another raster file that I CAN access from my WMS an it's located in a mapped unit:
DATA "\\iktfs1\Estatica$\ORTOFOTOS\Euskadi_2006_rgb_25cm_ed50.ecw"
It's weird isn't it?? I guess it could be something related to the named units or something like that.
More suggestions??
Thanks again.
Un saludo,
David Alda Fernández de Lezea
Lurralde eta Biodibertsitate Saila / Dpto. de Territorio y Biodiversidad
IKT
Granja Modelo s/n · 01192 · Arkaute (Araba)
Tlfnos.: 945-00-32-95 Fax: 945-00.32.90
email: dalda at ikt.es web: www.ikt.es
-----Mensaje original-----
De: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] En nombre de Rahkonen Jukka
Enviado el: miércoles, 03 de febrero de 2010 23:23
Para: mapserver-users at lists.osgeo.org
Asunto: Re: [mapserver-users] Access to a remote raster file in wms-mapfile
I guess that you will also need to configure Apache server so that it gives an access to the remote disk. I have not done it with IP-address but by assigning a drive letter for it first. This has a side effect that Apache cannot be installed as Windows service in a simple way.
-Jukka Rahkonen-
Daniel Morissette wrote:
I'd suggest you start by making sure GDAL can open the file:
Daniel
David Alda Fernandez de Lezea wrote:
> Hi list,
> I'm trying to access a remote raster file stored in NAS device (Iomega StorCenter Pro NAS 150D) which ip address is (192.168.1.4).
> In my mapfile I'm putting the url like this:
> DATA "\\192.168.1.4\ortofotos\EUSKADI_2009_ED50.ecw"
> But when I try to load the wms layer, I don't get anything and mapserver throws the following error:
> [Wed Feb 03 09:11:13 2010].67000 msDrawRaster(): Unable to access
> file. \\192.168.1.4\ortofotos\EUSKADI_2009_ED50.ecw using full path
> [Wed Feb 03 09:11:13 2010].67000 Unable to open file \\192.168.1.4\ortofotos\EUSKADI_2009_ED50.ecw for layer orto0 ... ignoring this missing data.
> [Wed Feb 03 09:11:13 2010].67000 msDrawMap(): Layer 1 (orto0), 0.000s
> The thing, is that if I type this url in my web browser, I get the file downloading. What I'm doing wrong? Any ideas?
> Thanks in advance.
> Un saludo,
> Biodiversidad
> IKT
> ············ _______________________________________________
Daniel Morissette
http://www.mapgears.com/
