[mapserver-users] mapserver as a tile cache client?
Bart van den Eijnden
bartvde at osgis.nl
Fri Feb 5 11:57:24 EST 2010
Some people made an extension to Geoserver to read ESRI mapcache, so maybe that could be used instead?
See:
http://download.osgeo.org/osgeo/foss4g/2009/SPREP/3Fri/Parkside%20Auditorium/1300/fri paud 1300 Jonsson.ppt
Best regards,
Bart
On Feb 5, 2010, at 4:17 PM, Christopher Schmidt wrote:
> On Fri, Feb 05, 2010 at 03:09:05PM +0000, John Pulles wrote:
>> Hi Bart,
>> Thanks for mentioning this!
>> I'm not getting the examples working though, with mapserver.
>> Apart from that, a problem with the arcgis mapcache is that it's tiles are
>> named like L01/R00000000/C00000000.png. Do you think the TMS minidriver
>> supports formatting of the {x}, {y} and {z}?
> It does not.
> -- Chris
>> Regards,
>> John
>> 2010/2/4 <bartvde at osgis.nl>
>>> John,
>>> yes it's possible see:
>>> http://www.gdal.org/frmt_wms.html
>>> Best regards,
>>> Bart
>>>> Hi,
>>>> We are having a arcgis tile cache layer but also need to have static
>>>> images
>>>> with a given bounding box, not limited by the tiling scheme, but making
>>> it
>>>> available as a wms. Is it possible to use mapserver as a tile cache
>>>> client,
>>>> or can you suggest other solutions?
>>>> Thanks,
>>>> John
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> mapserver-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Christopher Schmidt
> MetaCarta
