[mapserver-users] many raster projections
Andy Colson
andy at squeakycode.net
Mon Feb 8 12:05:48 EST 2010
Thank you, but that didnt seem to help.
I left the main PROJECTION as is, and I changed my raster to this:
LAYER
NAME "raster07"
STATUS off
TILEINDEX "raster07.shp"
TILEITEM "location"
TYPE RASTER
PROJECTION
"+proj=utm +zone=15 +ellps=GRS80 +datum=NAD83 +units=m +no_defs"
END
END
Now, here's another problem (to add to the layers of projections). I'm
using OpenLayers on the front end (for the website), and I have no idea
what all this projection stuff means, and wasnt sure how to set it in
OpenLayers.
I create the map like this:
map = new OpenLayers.Map("map", {
controls: [
new OpenLayers.Control.Navigation( {zoomWheelEnabled: false} ),
new OpenLayers.Control.PanZoomBar(),
ls
numZoomLevels: 12,
maxExtent: new OpenLayers.Bounds([%minx%], [%miny%], [%maxx%], [%maxy%]),
maxResolution: 250,
unit: 'm',
projection: "EPSG:2816"}
It seems to work. I totally guessed at EPSG:2816, I have no idea if it
matches:
"+proj=tmerc +lat_0=35.83333333333334 +lon_0=-92.5 +k=0.999933333
+x_0=500000 +y_0=0 +ellps=GRS80 +units=m +no_defs"
The shapefiles show up, as do most of the arials.
> Are these all publicly available datasets?
I dont know, they are from the Livingston county Missouri Assessors
office. Hum... did I say Minnesota before? That was wrong, its MO not
MN. Its about 2 gig, and I could email and ask them if it really comes
down to it.
-Andy
On 2/8/2010 10:36 AM, Fawcett, David (MPCA) wrote:
> Andy,
> It looks like you have data in at least two or three different
> projections. If you want to display them in the same map using
> MapServer, you need:
> - a projection block at the MAP level. This defines your output
> projection. The map UNITS and EXTENT need tobe consistent with this
> projection.
> - a projection block for each layer. This is used to tell MapServer
> what projection the data for that layer is currently in.
> MapServer then uses this info to warp all of the layers into the same
> output projection.
> Does this help?
> David.
> -----Original Message----- From:
> mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Andy
> Colson Sent: Monday, February 08, 2010 10:11 AM To: mapserver-users
> Subject: [mapserver-users] many raster projections
> Ok, I'm confused. Most of the problem is probably because I'm a
> programmer, not a mapper.
> I have arial imagery of Minnesota, multiple sets, each seeming to be
> in a different projection.
> At the top of my mapfile I have this:
> MAP EXTENT 1285920 1377857 1426390 1506589
> PROJECTION "+proj=tmerc +lat_0=35.83333333333334 +lon_0=-92.5
> +k=0.999933333 +x_0=500000 +y_0=0 +ellps=GRS80 +units=m +no_defs"
> END
> There are no other PROJECTION settings. Most of the images seem to
> work. I got the projtext above from loading one of the shapefiles
> into qgis and looking at its properties. I just kinda hoped they'd
> all be the same. I did try adding a PROJECTION to the raster layer,
> but it didnt seem to work. So I thought I'd "just" re-project the
> imagery.
> Three sets of imagery seem to work (I didnt touch them, they always
> worked), they have (again copied from qgis) proj text's of:
> +x_0=500000.0000000001 +y_0=0 +ellps=GRS80 +datum=NAD83
> +to_meter=0.3048006096012192 +no_defs
> +proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs
> and
> One set is displayed way off the map, way far away from where its
> supposed to be. Its projtext is:
> I attempted to use gdal_translate and gdal_warp.
> gdal_translate made a new image, with projtext: +proj=tmerc
> +lat_0=35.83333333333334 +lon_0=-92.5 +k=0.999933333 +x_0=500000
> but its in the exact same spot, it didnt re-position to where images
> are supposed to be.
> A gdalwarp moved it, but not to the right place.
> So I'm confused, and not sure what I'm doing. Hopefully there is
> some info in here someone can use to set me on the right path. Any
> help would be appreciated.
> -Andy _______________________________________________ mapserver-users
> mailing list mapserver-users at lists.osgeo.org
