[mapserver-users] INSIDE Idaho
Jon Miner
cp_n18 at yahoo.com
Tue Feb 9 06:47:51 EST 2010
Bringing this back onto the mailing list....
Re: [mapserver-users] INSIDE Idaho...
From: "greg.luker at scu.edu.au" <greg.luker at scu.edu.au>...Add to Contacts
To: Jon Miner <cp_n18 at yahoo.com>
______________________________
Hi Jon,
I'm very much NOT a mapserver expert (a beginner in fact), but one thing I noticed (it might mean nothing) is:
UNIT["Degree",0.0174532925199433]]
I
realise that ogr is saying this, but I thought UTM projection unit is
metre not degree, and I'm guessing that number (0.0174532925199433) is
how many degrees in a metre at that latitude.
Also the gdalinfo is
listing the origin and pixel size in metres. One thing you could do is
just put one layer in a mapfile and set the mapfile projection to NAD83
(or whatever the epsg code is for that) to see if you can actually see
the data at all, and then project it into what you need, using "metres"
(or maybe "meters") as the unit, somehow. Sorry I can't help more, but
maybe this might point you in a useful direction.
Thanks,
Greg.
----- Forwarded Message ----
To: gluker at scu.edu.au
Sent: Mon, February 8, 2010 8:16:22 PM
Subject: Re: [mapserver-users] INSIDE Idaho
Hi Greg -
I've looked at the parameters... Here is the DRG file:
http://data.insideidaho.org/data2/24k/usgs/drg/idtm/quad/nocollar/archive/43112/cirbu3se_24k_usgs_drg.tgz
So I extract that file and then run gdalinfo on the tif file:
gdalinfo cirbu3se_24k_usgs_drg.tif
Driver: GTiff/GeoTIFF
Files: cirbu3se_24k_usgs_drg.tif
Size is 4221, 5752
Coordinate System is `'
Origin = (590767.311137848766521,281203.236009103886317)
Pixel Size = (2.438400000000000,-2.438400000000000)
Metadata:
TIFFTAG_SOFTWARE=Arc/Info
TIFFTAG_XRESOLUTION=0.41
TIFFTAG_YRESOLUTION=0.41
TIFFTAG_RESOLUTIONUNIT=1 (unitless)
Image Structure Metadata:
COMPRESSION=PACKBITS
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( 590767.311, 281203.236)
Lower Left ( 590767.311, 267177.559)
Upper Right ( 601059.798, 281203.236)
Lower Right ( 601059.798, 267177.559)
Center ( 595913.554, 274190.398)
...etc...
Note the blank "coordinate system" entry... Using values from http://spatialreference.org, I came up with the PROJECTION values in my map file, which seems to work, since mapserver renders the DRG. So far so good...
Next I download some vector data:
http://data.insideidaho.org/data/USCB/TIGER2000/archive/butte/roadsl_butte_uscb.tgz
and extract it, then check it with ogrinfo:
$ ogrinfo roadsl_butte_uscb.shp roadsl_butte_uscb -so
INFO: Open of `roadsl_butte_uscb.shp'
using driver `ESRI Shapefile' successful.
Layer name: roadsl_butte_uscb
Geometry: Line String
Feature Count: 2596
Extent: (-113.641719, 43.284631) - (-112.694959, 44.233133)
Layer SRS WKT:
GEOGCS["GCS_North_American_1983",
DATUM["North_American_Datum_1983",
SPHEROID["GRS_1980",6378137.0,298.257222101]],
PRIMEM["Greenwich",0.0],
..etc..
If I'm not mistaken, I need to translate this to match the projection of the DRG file... I've been doing this with ogr2ogr:
ogr2ogr -t_srs idtm83.wkt -f "ESRI Shapefile" temp roadsl_butte_uscb.shp
where the idtm83.wkt contains:
PROJCS["NAD_1983_Transverse_Mercator",
DATUM["D_North_American_1983",
UNIT["Degree",0.0174532925199433]],
PROJECTION["Transverse_Mercator"],
PARAMETER["False_Easting",2500000.0],
PARAMETER["False_Northing",1200000.0],
PARAMETER["Central_Meridian",-114.0],
PARAMETER["Scale_Factor",0.9996],
PARAMETER["Latitude_Of_Origin",42.0],
UNIT["Meter",1.0]]
ogrinfo on the new file reports:
Feature Count: 2596
Extent: (2528908.642544, 1342938.885743) - (2605077.684651, 1448186.034775)
Layer SRS WKT:
UNIT["Degree",0.017453292519943295]],
UNIT["Meter",1.0]]
To me (as a programmer, not a map guru) everything seems to match up... Can you spot something that is not right?
Thanks
- Jon
Sent: Mon, February 8, 2010 5:50:47 PM
Hi John,
According to this page: http://inside.uidaho.edu/tutorial/data/data.htm all INSIDE data:
"are available in Idaho Transverse Mercator (IDTM) projection. Additionally, some data are available in Universal Transverse
Mercator (UTM) projection." (UTM zone 11 or zone 12). Parameters are here: http://inside.uidaho.edu/geodata/projparam.htm
Is this any help?
Thanks,
Greg.
Greg Luker
GIS Lab Manager
Southern Cross University
61 2 66203026
