[mapserver-users] php mapscript loadQuery problem
Moen, Paul T.
pmoen at nd.gov
Tue Feb 9 12:27:55 EST 2010
> Daniel Morissette wrote:
>> Moen, Paul T. wrote:
>> This is the error I get when dumping the error stack as described below.
>> Error in msEvalRegex(): String failed expression test.
> My first guess is that this error message comes from the file extension
> test on the filename of your query file. Your query file has to have a
> .qy extension if I'm not mistaken, otherwise MapServer won't open it.
Oops, I did not know that. I changed the extension to .qy and the loadQuery gives a MS_SUCCESS.
The right items are high lighted now but I get many of the following errors when I dumping the error stack.
Error in msEvalExpression(): Cannot evaluate expression, no item index defined.
This only seems to happen when there are many classes in the layer. Are these errors expected?
Thanks,
Paul
> This error message should definitely be improved.
> For the record, I have created a ticket to make sure we don't forget to
> fix this error message:
> http://trac.osgeo.org/mapserver/ticket/3302
> Daniel
> Daniel Morissette
> http://www.mapgears.com/
> mapserver-users at lists.osgeo.org
