[mapserver-users] MapScript wrapper for WxS
Peter Hopfgartner peter.hopfgartner at r3-gis.com
Wed Feb 17 07:18:05 EST 2010
Pavel Iacovlev wrote:
> Yes, and the bug is 3 years old. Setting the variables manually from
> $_GET works with no trouble.
Hi Pavel,
thank you for your quick help! Would it make sense, to add a comment in
the docs, at least?
Regards,
Peter
> On Wed, Feb 17, 2010 at 1:20 PM, Peter Hopfgartner
>>> try using instead of :
>>> $request = ms_newOwsrequestObj();
>>> $numValues = $request->loadparams();
>>> this:
>>> $request = ms_newowsrequestobj();
>>> foreach ($_GET as $key => $value) {
>>>    $request->setParameter($key, $value);
>> Hi Pavel,
>> this seems to work, so far. Is this realted to
>> http://trac.osgeo.org/mapserver/ticket/1975 ?
>> Peter
>> Would it
>>> On Wed, Feb 17, 2010 at 11:16 AM, Peter Hopfgartner
>>>> Hello
>>>> On a CentOS5, 64 bit machine I have a basic WMS through CGI, which runs
>>>> fine.
>>>> I'm trying to wrap this in a PHP script, like in
>>>> http://www.mapserver.org/ogc/mapscript.html:
>>>> <?php
>>>> /*exampple on how to modify the parameters :
>>>> forcing the version from 1.1.1 to 1.1.0 */
>>>> $request->setParameter("map","/data/sites/gisclient/mapset/map/wms_reti.map");
>>>> Logging to file I see that it is stops when calling loadparams(). It
>>>> returns
>>>> a document with 0 bytes.
>>>> On the same installation, the following Python wrapper gives the correct
>>>> Capabilities document:
>>>> #!/usr/bin/python
>>>> import mapscript
>>>> req = mapscript.OWSRequest()
>>>> req.loadParams()
>>>> map = mapscript.mapObj( '/data/sites/gisclient/mapset/map/wms_reti.map' )
>>>> map.OWSDispatch( req )
>>>> MapServer is 5.6.1. Trying on a machine with 5.2.2, the PHP script fails,
>>>> too.
>>>> Is there anything I am missing, here?
>>>> Thanks,
>>>> Peter
>>>> Dott. Peter Hopfgartner
>>>> R3 GIS Srl - GmbH
>>>> Via Johann Kravogl-Str. 2
>>>> I-39012 Meran/Merano (BZ)
>>>> Email: peter.hopfgartner at r3-gis.com
>>>> Tel. : +39 0473 494949
>>>> Fax  : +39 0473 069902
>>>> www  : http://www.r3-gis.com
>>>> XING: http://www.xing.com/go/invita/8917535
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> mapserver-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> R3 GIS Srl - GmbH
R3 GIS Srl - GmbH
XING : http://www.xing.com/go/invita/8917535
