[mapserver-users] Re: Blank image result after the call
http://localhost/mapserver/mapserv.exe?map=ecw.map&mode=map
Kiks
enrico.oemi at gmail.com
Fri Feb 19 05:43:58 EST 2010
Hi folks, thanks for the quick replies you have posted!
I tried to change the STATUS to DEFAULT and I removed the projection
information.
Now I can see the image created with the shp2img utility, and also with the
ALL_DEBUG option it seems to be all right!
But I still can't get an image in the browser with these calls:
http://localhost/mapserver/mapserv.exe?map=ecw.map&mode=map&layers=all
And when I call this:
http://localhost/mapserver/mapserv.exe?map=ecw.map&SERVICE=WMS&REQUEST=GetCapabilities
the reply is like before:
WMS Ortofoto 2048 2048 text/xml image/jpeg image/gif image/png image/png;
mode=24bit image/vnd.wap.wbmp image/tiff image/svg+xml text/plain
application/vnd.ogc.gml text/xml image/jpeg image/gif image/png image/png;
mode=24bit image/vnd.wap.wbmp text/xml XML INIMAGE BLANK Ortofoto Ortofoto
Ortofoto 1.54612e+006 1.55288e+006 4.94363e+006 4.95025e+006 ecw ecw
1.54612e+006 1.55288e+006 4.94408e+006 4.9498e+006
and if I add &VERSION=1.1.1, or if I try the GetMap with all the parameters
needed (BBOX, etc.) the browser (IE 8 and Chrome) ask me to download the
mapserv.exe !
Any other suggestion to debug the WMS service?
Thanks a lot,
Kiks
View this message in context: http://n2.nabble.com/Blank-image-result-after-the-call-http-localhost-mapserver-mapserv-exe-map-ecw-map-mode-map-tp4596732p4597157.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
