[mapserver-users] vertical alignment of symbols along a line
Fawcett, David (MPCA)
David.Fawcett at state.mn.us
Tue Feb 23 09:16:45 EST 2010
In your symbol definition, make your GAP value negative.
e.g.
SYMBOL
NAME "tie"
TYPE TRUETYPE
FONT "arial-bold"
CHARACTER "|"
GAP -4
ANTIALIAS TRUE
END
David.
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of windfreak
Sent: Tuesday, February 23, 2010 3:32 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] vertical alignment of symbols along a line
I use truetype fonts to render symbols along a line. The fonts are always
parallel to the line. Unfortunately I see the fonts are always centered
vertically along the line. Even symbols like the '^' or '`' symbol appear on
the line. How can I disable this vertical alignment?
Here you see an example of a triangle symbol that should appear above the
line. http://n2.nabble.com/file/n4617860/example.png
Here you see an example of the '^' symbol, also aligned on the line.
http://n2.nabble.com/file/n4617860/example2.png
http://www.topspots.org
View this message in context: http://n2.nabble.com/vertical-alignment-of-symbols-along-a-line-tp4617860p4617860.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
