[mapserver-users] Mapserver as a WMS server and as a WFS-client +
SLD problem
Jaakko Kahkonen
jaakko.kahkonen at fgi.fi
Tue Feb 23 09:24:01 EST 2010
Hello list,
I'm trying to upgrade MapServer 5.4.2 => 5.6.1, but my
WMS+SLD/WFS-client combination does not work after upgrading. WFS data
is fetched from GeoServer.
This is an obvious explanation from MapServer log:
msEvalRegex(): Regular expression error. String failed expression test.
But why - and how do I get over it?
Note that If I do not use SLD, Mapserver 5.6.1 works fine (see result:
MS561_noSLD_osm_2010.png).
Example request (with SLD parameter):
http://10.0.36.146/cgi-bin/osm_2010?LAYERS=planet_osm_line&FORMAT=image%2Fpng&SLD=http://10.0.36.146/sld/osm.xml&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A4258&BBOX=24.808341477283,60.151299935951,25.017877068694,60.360835527361&WIDTH=265&HEIGHT=265
Request returns SLD -styled map with MapServer 5.4.2 (see
MS542SLD_osm_2010.png)
nc10 cgi-bin # ./mapserv -v:
MapServer version 5.4.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG
SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS
INPUT=TIFF INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
ms_error.txt (mapserver-5.4.2, OK):
[Tue Feb 23 14:38:58 2010].64730 CGI Request 1 on process 31103
[Tue Feb 23 14:38:58 2010].229172 msApplySLD(): Map file after SLD was
applied
/var/www/localhost/htdocs/mapserver_oma/4b83cc62_797f_1._sld.map[Tue Feb
23 14:39:05 2010].854165 msDrawMap(): Layer 0 (planet_osm_line), 4.998s
[Tue Feb 23 14:39:05 2010].854241 msDrawMap(): Drawing Label Cache, 0.000s
[Tue Feb 23 14:39:05 2010].854281 msDrawMap() total time: 7.624s
[Tue Feb 23 14:39:06 2010].6693 msSaveImage() total time: 0.152s
[Tue Feb 23 14:39:06 2010].7107 mapserv request processing time
(msLoadMap not incl.): 7.942s
[Tue Feb 23 14:39:06 2010].7164 msFreeMap(): freeing map at 0x819be20.
With MapServer 5.6.1 request returns an empty map (see
MS561SLD_osm_2010.png).
MapServer version 5.6.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
SUPPORTS=CAIRO SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI
SUPPORTS=THREADS SUPPORTS=GEOS INPUT=TIFF INPUT=EPPL7 INPUT=POSTGIS
ms_error.txt (mapserver-5.6.1 NOT OK!!!):
[Tue Feb 23 14:42:34 2010].837252 CGI Request 1 on process 994
[Tue Feb 23 14:42:37 2010].405972 msEvalRegex(): Regular expression
[Tue Feb 23 14:42:37 2010].410682 msApplySLD(): Map file after SLD was
applied
/var/www/localhost/htdocs/mapserver_oma/4b83cd3d_3e2_3._sld.map[Tue Feb
23 14:42:40 2010].296531 msDrawMap(): Layer 0 (planet_osm_line), 1.610s
[Tue Feb 23 14:42:40 2010].296619 msDrawMap(): Drawing Label Cache, 0.000s
[Tue Feb 23 14:42:40 2010].296661 msDrawMap() total time: 2.864s
[Tue Feb 23 14:42:40 2010].448987 msSaveImage() total time: 0.152s
[Tue Feb 23 14:42:40 2010].449291 mapserv request processing time
(msLoadMap not incl.): 5.612s
[Tue Feb 23 14:42:40 2010].449331 msFreeMap(): freeing map at 0x81c9de0.
MapFile:
MAP
NAME OSM_2010
IMAGETYPE PNG
#EXTENT 57842.59 6622010.94 735699.26 7780000
EXTENT -380688 6247443 1347312 8227443
SIZE 600 600
UNITS METERS
CONFIG "MS_ERRORFILE"
"/var/www/localhost/htdocs/mapserver_oma/ms_error.txt"
DEBUG 5
OUTPUTFORMAT
NAME PNG
DRIVER AGG/PNG
MIMETYPE "image/png"
EXTENSION "png"
IMAGEMODE RGBA
FORMATOPTION INTERLACE=ON
FORMATOPTION QUALITY=100
END
WEB
IMAGEPATH "/var/www/localhost/htdocs/mapserver_oma/"
IMAGEURL "/mapserver_oma/"
LOG "/var/www/localhost/htdocs/mapserver_oma/"
METADATA
"ows_encoding" "UTF-8"
"ows_abstract" "Test"
"ows_title" "test2"
"ows_accessconstraints" "free"
"ows_srs" "EPSG:3067 EPSG:4258 EPSG:4326 EPSG:900913"
"ows_onlineresource" "http://10.0.36.146/cgi-bin/osm_2010?"
END
END
PROJECTION
"init=epsg:3067"
END
LAYER
NAME "planet_osm_line"
TYPE LINE
STATUS OFF
CONNECTIONTYPE WFS
CONNECTION "http://localhost:8080/geoserver/ows?"
METADATA
"ows_title" "Planet_osm_line"
"wfs_typename" "osm_suomi:planet_osm_line"
"wfs_version" "1.0.0"
"wfs_request_method" "GET"
"wfs_connectiontimeout" "30"
END
PROJECTION
"init=epsg:3067"
END
CLASS
NAME "residential"
STYLE
COLOR 255 0 0
SIZE 10
END
END
END
END
SLD (osm.xml):
<?xml version="1.0" encoding="utf-8"?>
<sld:StyledLayerDescriptor version="1.1.0"
schemaLocation="http://www.opengis.net/sld StyledLayerDescriptor.xsd"
xmlns="http://www.opengis.net/sld"
xmlns:ogc="http://www.opengis.net/ogc"
xmlns:se="http://www.opengis.net/se"
xmlns:xlink="http://www.w3.org/1999/xlink"
xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:sld="http://www.opengis.net/sld">
<sld:NamedLayer>
<se:Name>planet_osm_line</se:Name>
<sld:UserStyle>
<se:Name>Test</se:Name>
<se:Title>Test style</se:Title>
<se:FeatureTypeStyle>
<se:Rule>
<se:Name>Residential</se:Name>
<se:Title>Island</se:Title>
<ogc:Filter>
<ogc:PropertyIsEqualTo>
<ogc:PropertyName>highway</ogc:PropertyName>
<ogc:Literal>residential</ogc:Literal>
</ogc:PropertyIsEqualTo>
</ogc:Filter>
<se:LineSymbolizer>
<se:Stroke>
<se:SvgParameter name="stroke">#9C9C9C</se:SvgParameter>
<se:SvgParameter name="stroke-width">2</se:SvgParameter>
</se:Stroke>
</se:LineSymbolizer>
</se:Rule>
</se:FeatureTypeStyle>
</sld:UserStyle>
</sld:NamedLayer>
</sld:StyledLayerDescriptor>
Jaska K.
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100223/d1b8f747/MS542SLD_osm_2010-0001.png
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100223/d1b8f747/MS561_noSLD_osm_2010-0001.png
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100223/d1b8f747/MS561SLD_osm_2010-0001.png
