[mapserver-users] small maps of alaska and hawaii
    Julie Knoll
    julieknoll at gmail.com
    Tue Feb 23 08:07:59 PST 2010
We aren't using open layers, its a completely custom written site. It could
definitely be done, but then there would be a lot of processing going on the
background x 3 and I don't think thats practicle.  I also thought about just
physically moving the shapes closer to the US, but theres about 15 layers
that would have to be updated, that still might just be easiest though.  I
was hoping there was maybe someway I could use mapservers querymap feature
to do this, but I guess not?
On Tue, Feb 23, 2010 at 10:03 AM, Stephen Woodbridge <
woodbri at swoodbridge.com> wrote:
> If you are using something like OpenLayers under the hood, you might just
> create three separate maps, one for each region. You can set the maxextents
> for each map to prevent scrolling outside that area.
> This way each map would have its own controls and its own div and each
> could respond to events in their respective div.
> This is definitely not a mapserver issue, but it is an interesting problem.
> -Steve
> Julie Knoll wrote:
>> Thats what I originally thought about doing, but I don't know how I would
>> go about converting it to the right coordinates when the user clicks on the
>> map. The site I'm working on is http://geofred.stlouisfed.org  There's so
>> many other things going on server side to calculate the data and what not
>> that maybe its just not worth the effort.
>> Julie
>> On Mon, Feb 22, 2010 at 1:35 PM, Stephen Woodbridge <
>> woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>>    Julie Knoll wrote:
>>        Hi, I am working on a site that displays thematic data for the
>>        United States, and I would like to include small maps for Alaska
>>        and Hawaii in the corners of the main map, rather than having to
>>        zoom so far out to see them.  Does anyone have any suggestions
>>        about the best way of going about doing this? Thanks.
>>    This is really a composition problem where you need to compose a
>>    single image from multiple separate images. The answer really
>>    depends on what media you are using like html, pdf, etc.
>>    If you are trying to do this in a web application I would recommend
>>    an approach some like:
>>    Using PHP/Mapscript, generate you three images and then use PHP GD
>>    to compose the three images into a single image and then return that
>>    to the browser. You can use a similar approach if you are using PDF
>>    depending on the PDF lib you are using.
>>    -Steve W
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100223/7ffface4/attachment.htm>
More information about the MapServer-users
