[mapserver-users] WFS query problem (MS 5.0)
Bart van den Eijnden
bartvde at osgis.nl
Wed Feb 24 04:43:16 EST 2010
Hi James,
all data sources are PostGIS. I am sure the WFS request is valid.
It only happens if I click somewhere where one of the two layers has no data, if I click somewhere where both layers have data all is fine.
Best regards,
Bart
On Feb 24, 2010, at 10:39 AM, James Perrins wrote:
> Hi Bart,
> I imagine you've thought of these (and from your post that you are
> sure that your WFS request is valid - and that it should be returning
> data) - but just in case:
> - Does this happen all the time - or only on some areas / requests ?
> We have had issues with certain more complex gemometry types - or some
> geometries that are questionably formed
> - Where is the data coming from ?
> We've had issues with data sources that can supply mixed geometry
> types - or even I think grouped layers where it included perhaps
> points for one zoom level and polygons for another
> Sorry - can't help with version numbers - don't keep track of that
> stuff too carefully
> Good luck
> On Wed, Feb 24, 2010 at 8:28 AM, Bart van den Eijnden <bartvde at osgis.nl> wrote:
>> Hi list,
>> I need someone with a good memory on Mapserver history :-)
>> I am running into what I believe is an old bug in Mapserver WFS,
>> unfortunately we are still running an old MS 5.0.0.
>> When doing a WFS query and one of the layers returns an error (like no
>> matching records found), no feature collection is returned but only the
>> error message.
>> Can someone remember this bug, and also if there is a workaround, if no
>> workaround then in what version was this fixed? TIA.
>> <ServiceExceptionReport
>> xmlns="http://www.opengis.net/ogc"
>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>> xsi:schemaLocation="http://www.opengis.net/ogc
>> http://schemas.opengis.net/wms/1.1.1/OGC-exception.xsd">
>> <ServiceException>
>> msQueryByRect(): Search returned no results. No matching record(s) found.
>> </ServiceException>
>> </ServiceExceptionReport>
>> Best regards,
>> Bart
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Dr James Perrins
> exeGesIS SDM Ltd
> Great House Barn
> New Street, Talgarth
> Powys LD3 0AH.
> Direct Line: 01646 686650
> Tel: 01874 711145
> Fax: 01874 711156
> Email: JamesP at esdm.co.uk
> This E-mail and any files transmitted with it are private and intended
> solely for the use of the individual or entity to whom they are
> addressed. If you are not the intended recipient, the E-mail and any
> files have been transmitted to you in error and any copying,
> distribution or other use of the information contained in them is
> strictly prohibited.
> Nothing in this E-mail message amounts to a contractual or other legal
> commitment on the part of exeGesIS SDM Ltd unless confirmed by a
> signed communication.
> exeGesIS SDM Ltd will make every effort to keep its network free of
> viruses. However, the recipient of this message will need to scan this
> message, and any attachments, for viruses, as exeGesIS SDM Ltd can
> take no responsibility for any computer virus that might be
> transferred by this e-mail.
