[mapserver-users] SQL Server 2008 driver and Reduce() Function
jwschrader
schraj at gmail.com
Fri Feb 26 14:11:32 EST 2010
I've been trying to reduce some complex polygons(Washington State Census
Tract Boundaries) so that I can improve the mapserver's response time in
generating maps. This is a technique that works fine when taking the
geometries directly from Sql Server and rendering them dynamically on the
client.
I have also called the MakeValid() method on the reduced geometries as
suggested in this post:
http://johanneskebeck.spaces.live.com/blog/cns!42E1F70205EC8A96!7718.entry
When using Shp2Img with the reduced geometries, I get a blank layer and the
debugging message is:
msMSSQLLayerGetShapeRandom bad shape: #
Thanks for any ideas.
Cheers,
Jeremy
View this message in context: http://n2.nabble.com/SQL-Server-2008-driver-and-Reduce-Function-tp4641185p4641185.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
