[mapserver-users] Re: SQL Server 2008 driver and Reduce() Function
jwschrader
schraj at gmail.com
Fri Feb 26 16:44:26 EST 2010
Thanks for the quick response.
I misspoke. The map displays another layer(county boundaries) that is
pulled from a shape file and just the layer that uses the "reduced" geometry
is blank.
Also, these reduced geometries are not null. When I run a STIsValid()
function, they return 1.
Jeremy
View this message in context: http://n2.nabble.com/SQL-Server-2008-driver-and-Reduce-Function-tp4641185p4642068.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
