[mapserver-users] How to add HDF-EOS data layer in MapServer
Ivan ivan.lucena at pmldnet.com
Sun Feb 28 23:18:24 EST 2010
Venkat,
I am sorry. Your previous e-mail didn't show the SUBDATASET and then I assumed that you are dealing
with one unsupported flavor of HDF. But if it showing, great!
If you could use gdal_translate to convert to GeoTIFF you can use the same identification string on
a DATA parameter.
So, if you ran gdal_translate like that:
gdal_translate HDF5:OMI.he5://HDFEOS/GRIDS/OMI_Column_Amount_O3/Data_Fields/ColumnAmountO3 output.tif
Then you should be able to use the same identification on your map file like that:
LAYER
   TYPE RASTER
   DATA "HDF5:OMI.he5://HDFEOS/GRIDS/OMI_Column_Amount_O3/Data_Fields/ColumnAmountO3"
Some time ago I reported a bug in Mapserver that was preventing those complex GDAL connection string
to work but I believe its fixed now.
Please, give it a try and let us know if it works or not. And don't forget to mention the GDAL and
Mapserver version that you are using.
Regards,
Ivan
Venkat Shesu Reddem wrote:
> Hi Ivan,
> gdalinfo is showing subdataset list also, the previous mail contains
> gdalinfo of one of subdataset.  I have used gdal_translate to convert
> the following in GeoTIFF image, however i don't have idea about how to
> create layer for the given hdf subdataset.
> the below is the gdalinfo showing subdataset list:
> Driver: HDF5Image/HDF5 Dataset
> Files: none associated
> Size is 1440, 720
> Coordinate System is:
> GEOGCS["WGS 84",
>     DATUM["WGS_1984",
>         SPHEROID["WGS 84",6378137,298.257223563,
>             AUTHORITY["EPSG","7030"]],
>         TOWGS84[0,0,0,0,0,0,0],
>         AUTHORITY["EPSG","6326"]],
>     PRIMEM["Greenwich",0,
>         AUTHORITY["EPSG","8901"]],
>     UNIT["degree",0.0174532925199433,
>         AUTHORITY["EPSG","9108"]],
>     AUTHORITY["EPSG","4326"]]
> Metadata:
>   FILE_ATTRIBUTES:OrbitNumber=29703 29704 29705 29706 29707 29708
> 29709 29710 29711 29712 29713 29714 29715 29716 29717 29718 29719
> 29720 29721 29722 29723 29724 29725 29726 29727 29728 29729 29730
> 29731 29732 29733 29734 29735 29736 29737 29738 29739 29740 29741
> 29742 29743 29744 29745 29746 29747
>   FILE_ATTRIBUTES:OrbitPeriod=5933 5934 5933 5934 5933 5934 5933 5934
> 5933 5934 5933 5933 5934 5933 5934 5933 5934 5933 5934 5933 5934 5933
> 5934 5933 5934 5933 5934 5933 5934 5933 5934 5933 5933 5934 5934 5933
>   FILE_ATTRIBUTES:InstrumentName=OMI
>   FILE_ATTRIBUTES:ProcessLevel=3e
>   FILE_ATTRIBUTES:GranuleMonth=2
>   FILE_ATTRIBUTES:GranuleDay=15
>   FILE_ATTRIBUTES:GranuleYear=2010
>   FILE_ATTRIBUTES:GranuleDayOfYear=46
>   FILE_ATTRIBUTES:TAI93At0zOfGranule=5.40346e+008
>   FILE_ATTRIBUTES:PGEVersion="1.0.5.1"
>   FILE_ATTRIBUTES:StartUTC=2010-02-14T12:15:00.000000Z
>   FILE_ATTRIBUTES:EndUTC=2010-02-16T11:45:00.000000Z
>   FILE_ATTRIBUTES:Period=Daily
>   OMI Column Amount O3:GCTPProjectionCode=0
>   OMI Column Amount O3:Projection=Geographic
>   OMI Column Amount O3:GridOrigin=Center
>   OMI Column Amount O3:GridSpacing=(0.25,0.25)
>   OMI Column Amount O3:GridSpacingUnit=deg
>   OMI Column Amount O3:GridSpan=(-180,180,-90,90)
>   OMI Column Amount O3:GridSpanUnit=deg
>   OMI Column Amount O3:NumberOfLongitudesInGrid=1440
>   OMI Column Amount O3:NumberOfLatitudesInGrid=720
>   HDFEOS INFORMATION:HDFEOSVersion=HDFEOS_5.1.11
> Corner Coordinates:
> Upper Left  (    0.0,    0.0)
> Lower Left  (    0.0,  720.0)
> Upper Right ( 1440.0,    0.0)
> Lower Right ( 1440.0,  720.0)
> Center      (  720.0,  360.0)
> Band 1 Block=1440x1 Type=Float32, ColorInterp=Undefined
>   Metadata:
>     RadiativeCloudFraction:_FillValue=-1267650600228229400000000000000.000000
>     RadiativeCloudFraction:Units=NoUnits
>     RadiativeCloudFraction:Title=Radiative Cloud Fraction = fc*Ic331/Im331
>     RadiativeCloudFraction:UniqueFieldDefinition=TOMS-OMI-Shared
>     RadiativeCloudFraction:ScaleFactor=1
>     RadiativeCloudFraction:Offset=0
>     RadiativeCloudFraction:ValidRange=0.000000 1.000000
>     RadiativeCloudFraction:MissingValue=-1267650600228229400000000000000.000000
> Driver: HDF5/Hierarchical Data Format Release 5
> Files: OMI.he5
> Size is 512, 512
> Coordinate System is `'
> Metadata:
> Subdatasets:
>   SUBDATASET_0_NAME=HDF5:"OMI.he5"://HDFEOS/GRIDS/OMI_Column_Amount_O3/Data_Fields/ColumnAmountO3
>   SUBDATASET_0_DESC=[720x1440]
> //HDFEOS/GRIDS/OMI_Column_Amount_O3/Data_Fields/ColumnAmountO3 (32-bit
> floating-point)
>   SUBDATASET_1_NAME=HDF5:"OMI.he5"://HDFEOS/GRIDS/OMI_Column_Amount_O3/Data_Fields/RadiativeCloudFraction
>   SUBDATASET_1_DESC=[720x1440]
> (32-bit floating-point)
>   SUBDATASET_2_NAME=HDF5:"OMI.he5"://HDFEOS/GRIDS/OMI_Column_Amount_O3/Data_Fields/SolarZenithAngle
>   SUBDATASET_2_DESC=[720x1440]
>   SUBDATASET_3_NAME=HDF5:"OMI.he5"://HDFEOS/GRIDS/OMI_Column_Amount_O3/Data_Fields/ViewingZenithAngle
>   SUBDATASET_3_DESC=[720x1440]
> Corner Coordinates:
> Lower Left  (    0.0,  512.0)
> Upper Right (  512.0,    0.0)
> Lower Right (  512.0,  512.0)
> Center      (  256.0,  256.0)
> with thanks & regards
> Venkat
> On Fri, Feb 26, 2010 at 4:21 PM, Ivan Lucena <ivan.lucena at pmldnet.com> wrote:
>> Hi Venkat,
>> If gdalinfo is not showing the subdataset list, like in you case, it would be impossible to identify a dataset as your DATA parameter.
>> What version is the GDAL that you are using on command line? Is that the same that mapserver is using?
>> Note that there are some flavors of HDF products that are not supported by all version of GDAL/HDF.
>> Regards,
>> Ivan
>>>  -------Original Message-------
>>>  From: Venkat Shesu Reddem <venkat.shesu at gmail.com>
>>>  To: mapserver-users at lists.osgeo.org
>>>  Subject: [mapserver-users] How to add HDF-EOS data layer in MapServer
>>>  Sent: Feb 26 '10 11:02
>>>  Dear All,
>>>  I am trying to add HDF-EOS data layer to MapServer application. Can anyone
>>>  help me in defining the syntax of the layer.
>>>  the following is the "gdalinfo" for the given HDF dataset
>>>  Size is 1440, 720
>>>  GEOGCS["WGS 84",
>>>     DATUM["WGS_1984",
>>>  Metadata:
>>>  FILE_ATTRIBUTES:OrbitNumber=29703 29704 29705 29706 29707 29708 29709
>>>  29710 29711 29712 29713 29714 29715 29716 29717 29718 29719 29720 29721
>>>  29722 29723 29724 29725 29726 29727 29728 29729 29730 29731 29732 29733
>>>  29734 29735 29736 29737 29738 29739 29740 29741 29742 29743 29744 29745
>>>  29746 29747
>>>  FILE_ATTRIBUTES:OrbitPeriod=5933 5934 5933 5934 5933 5934 5933 5934 5933
>>>  5934 5933 5933 5934 5933 5934 5933 5934 5933 5934 5933 5934 5933 5934 5933
>>>  5934 5933 5934 5933 5934 5933 5934 5933 5933 5934 5934 5933 5934 5933 5933
>>>  Corner Coordinates:
>>>  Metadata:
>>>  Venkat
>>>  _______________________________________________
>>>  mapserver-users mailing list
>>>  http://lists.osgeo.org/mailman/listinfo/mapserver-users
