[mapserver-users] How to render raster data using Oracle
Georaster?
xxj
2001xxj at gmail.com
Fri Jan 1 06:38:20 EST 2010
Hi Ivan,
Thanks for help!
Unfortunately, I got the same errors after commenting out the two lines in
mapstring.c and recompiling the whole application. It seems that GDAL is not
called when MapServer try to get a GeoRaster data set. Are you sure that
just commenting out the two lines can work? Please can you post your map
file in the thread I mentioned? For I want to have it as a reference.
Regards,
xxj
Ivan-5 wrote:
> Hi Xxj,
> As I wrote before. There are code in Mapserver that wrongly assume that
> raster DATA is always file
> based. The code is in mapstring.g lines 668 and 695. If you comment out
> those two lines I believe
> you could make it work.
> http://trac.osgeo.org/mapserver/browser/trunk/mapserver/mapstring.c#L668
> http://trac.osgeo.org/mapserver/browser/trunk/mapserver/mapstring.c#L695
> I would suggest you to file a bug report on that issue.
> The thread that you mentioned was about another bug that I detected.
> Mapsever wasn't using GDAL
> raster overviews at all. Not only GeoRaster. And it makes a big difference
> when displaying GeoRaster
> to have Pyramids/Overviews properly supported as you can see also with
> Oracle's Mapviewer.
> Best regards,
> Ivan
> xxj wrote:
>> Hi,
>> Please have a look at this thread.
>> http://n2.nabble.com/MapServer-Oracle-performance-td3529225.html#a3531606
>> According to the replies by Ivan-5, it seems that he has ever succeeded
>> in
>> rendering raster data using Oracle GeoRaster. How did he make it?
>> I also noticed that you get the same user name in this forum. May I
>> assume
>> that you are exactly the guy? :)
>> Regards,
>> xxj
> mapserver-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/How-to-render-raster-data-using-Oracle-Georaster-tp4235902p4239315.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
