[mapserver-users] Problem with Russia polygon
Rahkonen Jukka Jukka.Rahkonen at mmmtike.fi
Mon Jan 4 17:03:29 EST 2010
Unfortunately the extents are OK and the problem is something more complicated.  Extents are indeed in meters but that's how they must be because the MAP level projection looks like this:
PROJECTION
"init=epsg:900913"
END
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: mapserver-users-bounces at lists.osgeo.org puolesta: Barend Köbben
Lähetetty: ma 4.1.2010 22:52
Vastaanottaja: Nelson Correia; Lime, Steve D (DNR); Andy Colson
Kopio: mapserver-users at lists.osgeo.org
Aihe: Re: [mapserver-users] Problem with Russia polygon
You've got data that is in latlong (units decimal degrees) in your
shapefile, however in the EXTENT part of the map file you use
    EXTENT -20037508 -13590765 20037508 11229864
Which are not latlomngs but some projected coordinates, and
    UNITS meters
IN the LAYER you tell mapserver that its:
PROJECTION
            "proj=longlat"
            "datum=WGS84"
            "no_defs"
        END
These two are contradictory. You'll have to match the PROJECTION in the
LAYER to the actual projection and units (apparentlt these are correct) ,
and make sure the EXTENT is expressed in the same system. So best thing is
to set the EXTENT in latlons (as its the whole world -180 -90 180 90 is a
safe bet) and UNITS to degrees...
Yours,
Barend Köbben
Senior Lecturer
University of Twente, Faculty of Geo-Information Science and
Earth Observation (ITC)
PO Box 6, 7500AA Enschede, The Netherlands
+31 (0)53 4874253
On 04-01-10 19:34, "Nelson Correia" <nelson-correia at telecom.pt> wrote:
> Here is the simplified shapefile, along with a mapfile that uses it:
> http://www.2shared.com/file/10449234/a18d6a03/countries.html
> Nelson
> -----Original Message-----
> From: Lime, Steve D (DNR) [mailto:Steve.Lime at state.mn.us]
> Sent: segunda-feira, 4 de Janeiro de 2010 17:28
> To: Nelson Correia; Barend Köbben; Andy Colson
> Cc: mapserver-users at lists.osgeo.org
> Subject: RE: [mapserver-users] Problem with Russia polygon
> Would be interesting to get a copy of the data in shapefile format, plus the
> mapfile that generates the error...
> Steve
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Nelson Correia
> Sent: Monday, January 04, 2010 7:32 AM
> To: Barend Köbben; Andy Colson
> Hello,
> All the russian polygons are valid (st_valid) and closed (st_closed). The
> problem seems to be in the vertical lines at 180º and -180º that divide
> certain areas of the country. It seems like when mapserver tries to draw these
> lines, there's some kind of unknown behavior that make it draw horizontal
> lines instead, resulting in very strange polygons.
> However, I have not solved the problem yet.
> Nelson
> From: Barend Köbben [mailto:kobben at itc.nl]
> Sent: sábado, 2 de Janeiro de 2010 15:33
> To: Andy Colson; Nelson Correia
> Subject: Re: [mapserver-users] Problem with Russia polygon
> Hi,
>> I guess to make a long story short, do you have any editors (like qgis) that
>> you can use to see/edit the layer and make sure  each record is valid?
> You can use PostGIS's ST_IsValid() for that.
> The problem of Nelson seems to me to be a 'dateline' problem: you have
> coordinates in latlon and some polygons are crossing the dateline (and/or
> the poles), therefore the coordinates' sign jumps from - to + (or from E to
> W). If you then draw that in a Plate Carree 'projection (where latitudes and
> longitudes are treated as if they were Cartesian coordinates , which they
> surely aren't: they are angles from the middle of the Earth!), then the
> polygon jumps from the extreme right to the extreme left of the picture...
> Barend Köbben
> Senior Lecturer
> +31 (0)53 4874253
> On 02-01-10 15:50, "Andy Colson" <andy at squeakycode.net> wrote:
>> On 12/30/2009 11:14 AM, Nelson Correia wrote:
>>> Hello,
>>> I¹m using shapefile world data from gadm.org (I¹ve had this same problem
>>> with other data sources too) and I¹m having a problem with the Russian
>>> polygon: mapserver draws some strange lines parallel to the equator,
>>> near the north pole (like you can see in the attached image).
>>> Anyone had the same problem and knows how to solve it?
>>> Thanks,
>>> Nelson
>> I have no idea if this is the same problem, but I have run into weird drawing
>> problems before.  I import shape files into PostGIS and then use mapserver on
>> that.  I got a polygon layer that had an unclosed line (I guess that is a
>> good
>> way to describe it).  It pissed off mapserver.  I could run sql like:
>> select gid from layer where not ST_IsClosed(the_geom)
>> and it would pull it up.  The people that sent me the layer swore there was
>> nothing wrong with it (they didn't see any error).
>> -Andy
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> International Institute for Geo-Information Science and Earth Observation
> (ITC)
> Chamber of Commerce: 410 27 560
> E-mail disclaimer
> The information in this e-mail, including any attachments, is intended for the
> addressee only. If you are not the intended recipient, you are hereby notified
> that any disclosure, copying, distribution or action in relation to the
> content of this information is strictly prohibited. If you have received this
> e-mail by mistake, please delete the message and any attachment and inform the
> sender by return e-mail. ITC accepts no liability for any error or omission in
> the message content or for damage of any kind that may arise as a result of
> e-mail transmission.
Faculty of Geo-Information Science and Earth Observation (ITC)
E-mail disclaimer
The information in this e-mail, including any attachments, is intended for the addressee only. If you are not the intended recipient, you are hereby notified that any disclosure, copying, distribution or action in relation to the content of this information is strictly prohibited. If you have received this e-mail by mistake, please delete the message and any attachment and inform the sender by return e-mail. ITC accepts no liability for any error or omission in the message content or for damage of any kind that may arise as a result of e-mail transmission.
