[mapserver-users] Error configuring WMS app : Projection library
error. Invalid argument...
Daniel Walton
dgwalton at gmail.com
Tue Jan 5 11:07:32 EST 2010
Stella,
Try adding a config entry to your mapfile that points to the folder
containing your epsg configuration file:
MAP
CONFIG "PROJ_LIB" "C:/somedir/proj/nad/"
END
Dan Walton
[image: Linkedin] <http://www.linkedin.com/in/danielwalton2010>[image:
Twitter] <http://twitter.com/danwallie>
On Tue, Jan 5, 2010 at 9:56 AM, stela anders <stelaanders at gmail.com> wrote:
> Hello Frank!
> Thanks for your time ;)
> I´m working on Windows 7...
> I made all modifications you suggest me, but got the same error...
> The URL now is :
> http://localhost/cgi-bin-last/mapserv.exe?MAP=C:/inetpub/wwwroot/Openlayer/Mapserver/Mapfile/Map.map&LAYERS=Argentina&TRANSPARENT=true&FORMAT=image/png&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application/vnd.ogc.se_inimage&SRS=EPSG:4326&BBOX=-62.9142,-17.3676,-57.2892,-11.7426&WIDTH=256&HEIGHT=256
> The only difference that I noticed is that the error in browser now is in
> TEXT format...
> Before the error was write in a Image...
> I´m completely lost ! :(
> Any other idea?
> ps.: Sorry for my bad english
> Stella
> 2010/1/5 Frank Warmerdam <warmerdam at pobox.com>
> stela anders wrote:
>>> LAYER
>>> NAME Argentina
>>> METADATA
>>> "wms_title" "Argentina" ##required
>>> END TYPE POLYGON
>>> STATUS ON
>>> INCLUDE "Connection.map" DATA "the_geom from
>>> tbl_argentina USING UNIQUE gid USING SRID=0"
>>> PROJECTION
>>> "proj=longlat"
>>> "ellps=WGS84"
>>> "datum=WGS84"
>>> "no_defs"
>>> END
>>> CLASS
>>> COLOR 255 200 255
>>> END
>>> END
>>> END
>>> When I try to open that with my OpenLayer app, I got images with that
>>> error :
>>> Error: msProcessProjection(): /Projection library error/. /Invalid
>>> argument
>> Stella,
>> I am not sure why you are getting this error. I search high and low and
>> can't
>> find "Invalid argument" in either MapServer or PROJ.4. Are you working on
>> linux or Windows? Were the "/" characters really in this message? It is
>> hard for me to understand how this could happen.
>> With regard to your mapfile, I was surprised that you don't have
>> wms_srs metadata on your layer. It is a shot in the dark, but perhaps you
>> could add wms_srs EPSG:4326 metadata on the layer, and reorder the wms_srs
>> metadata on the map to put EPSG:4326 first.
>> Also, you could try changing:
>> > PROJECTION
>> > "proj=longlat"
>> > "ellps=WGS84"
>> > "datum=WGS84"
>> > "no_defs"
>> > END
>> to:
>> PROJECTION
>> "+init=epsg:4326"
>> END
>> in both the layer and map. This is slower to expand but it might
>> make it easier for mapserver to relate to epsg codes.
>> Best regards,
>> I set the clouds in motion - turn up | Frank Warmerdam,
>> light and sound - activate the windows | http://pobox.com/~warmerdam<http://pobox.com/%7Ewarmerdam>
>> and watch the world go round - Rush | Geospatial Programmer for Rent
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100105/84937ce3/attachment.html
