[mapserver-users] Error configuring WMS app : Projection libr ary error. Invalid argument...
Fuchs Juan Carlos jfuch at indec.mecon.gov.ar
Wed Jan 6 07:46:38 EST 2010
Hi Stela
I will add my 10 cents to Frank´s answer
you put
DATA "the_geom from tbl_argentina USING UNIQUE gid USING SRID=0"
¿don´t it have to say
DATA "the_geom from tbl_argentina USING UNIQUE gid USING SRID=-1"
-----Mensaje original-----
De: Frank Warmerdam [mailto:warmerdam at pobox.com]
Enviado el: Martes, 05 de Enero de 2010 12:03 p.m.
Para: stela anders
Asunto: Re: [mapserver-users] Error configuring WMS app : Projection
library error. Invalid argument...
stela anders wrote:
>         LAYER
>         NAME Argentina
>         METADATA
>             "wms_title"    "Argentina"   ##required
>         END
>         TYPE POLYGON
>         STATUS ON
>         INCLUDE "Connection.map"
>         PROJECTION
>             "proj=longlat"
>             "ellps=WGS84"
>             "datum=WGS84"
>             "no_defs"
>         END
>         CLASS
>             COLOR 255 200 255
>         END
>         END
> When I try to open that with my OpenLayer app, I got images with that
> error :
> Error: msProcessProjection(): /Projection library error/. /Invalid
I am not sure why you are getting this error.  I search high and low and
find "Invalid argument" in either MapServer or PROJ.4.  Are you working on
linux or Windows?  Were the "/" characters really in this message?  It is
hard for me to understand how this could happen.
With regard to your mapfile, I was surprised that you don't have
wms_srs metadata on your layer.  It is a shot in the dark, but perhaps you
could add wms_srs EPSG:4326 metadata on the layer, and reorder the wms_srs
metadata on the map to put EPSG:4326 first.
Also, you could try changing:
 >         PROJECTION
 >             "proj=longlat"
 >             "ellps=WGS84"
 >             "datum=WGS84"
 >             "no_defs"
 >         END
in both the layer and map.  This is slower to expand but it might
make it easier for mapserver to relate to epsg codes.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
mapserver-users mailing list
mapserver-users at lists.osgeo.org
