[mapserver-users] Error configuring WMS app : Projection library
error. Invalid argument...
stela anders
stelaanders at gmail.com
Wed Jan 6 08:14:45 EST 2010
Guys, other problem now ;(
I have 2 layers with same name ... One with LINE and other with ANNOTATION
... It works fine in mapscript environment... But now, with WMS I got a
error when I use both layers with same name:
msWMSLoadGetMapParams(): *WMS server error*. *Invalid layer*(s) given in the
*LAYERS* parameter
Both layer works separately...
My 2 layers
LAYER
NAME Road
METADATA
"wms_title" "Road"
END
GROUP "Transport"
TYPE LINE
STATUS ON
INCLUDE "Connection.map"
DATA ...
PROJECTION
"+init=epsg:4326"
END
CLASS
TEMPLATE "dummy"
NAME "Rod x"
STYLE
SYMBOL "road"
COLOR 0 0 0
ANTIALIAS TRUE
END
END
END
LAYER
NAME Road
METADATA
"wms_title" "Road"
END
GROUP "Transport"
TYPE ANNOTATION
STATUS ON
DATA ...
PROJECTION
"+init=epsg:4326"
END
LABELITEM 'rod'
CLASS
TEMPLATE "dummy"
STYLE
SYMBOL 'roadsymbol'
END
LABEL
TYPE TRUETYPE
FONT Arial
SIZE 7
COLOR 70 70 70
MINDISTANCE 100
MINFEATURESIZE 10
PARTIALS FALSE
BUFFER 10
END
END
END
Why?
Thanks and sorry for noob questions
Stella
2010/1/5 Daniel Walton <dgwalton at gmail.com>
> You're welcome Stella. I struggled through the Windows WMS stuff a few
> months ago, glad to help.
> -Dan
> On Tue, Jan 5, 2010 at 10:18 AM, stela anders <stelaanders at gmail.com>wrote:
>> Woww!
>> Thats it!!!!
>> Worked now!
>> Thanksss guysss ! Thanks Daniel!
>> iuupi!
>> Stella
>> Stella,
>>> Try adding a config entry to your mapfile that points to the folder
>>> containing your epsg configuration file:
>>> MAP
>>> CONFIG "PROJ_LIB" "C:/somedir/proj/nad/"
>>> END
>>> Dan Walton
>>> [image: Linkedin] <http://www.linkedin.com/in/danielwalton2010>[image:
>>> Twitter] <http://twitter.com/danwallie>
>>> On Tue, Jan 5, 2010 at 9:56 AM, stela anders <stelaanders at gmail.com>wrote:
>>>> Hello Frank!
>>>> Thanks for your time ;)
>>>> I´m working on Windows 7...
>>>> I made all modifications you suggest me, but got the same error...
>>>> The URL now is :
>>>> http://localhost/cgi-bin-last/mapserv.exe?MAP=C:/inetpub/wwwroot/Openlayer/Mapserver/Mapfile/Map.map&LAYERS=Argentina&TRANSPARENT=true&FORMAT=image/png&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application/vnd.ogc.se_inimage&SRS=EPSG:4326&BBOX=-62.9142,-17.3676,-57.2892,-11.7426&WIDTH=256&HEIGHT=256
>>>> The only difference that I noticed is that the error in browser now is
>>>> in TEXT format...
>>>> Before the error was write in a Image...
>>>> I´m completely lost ! :(
>>>> Any other idea?
>>>> ps.: Sorry for my bad english
>>>> Stella
>>>> 2010/1/5 Frank Warmerdam <warmerdam at pobox.com>
>>>> stela anders wrote:
>>>>>> LAYER
>>>>>> NAME Argentina
>>>>>> METADATA
>>>>>> "wms_title" "Argentina" ##required
>>>>>> END TYPE POLYGON
>>>>>> STATUS ON
>>>>>> INCLUDE "Connection.map" DATA "the_geom from
>>>>>> tbl_argentina USING UNIQUE gid USING SRID=0"
>>>>>> PROJECTION
>>>>>> "proj=longlat"
>>>>>> "ellps=WGS84"
>>>>>> "datum=WGS84"
>>>>>> "no_defs"
>>>>>> END
>>>>>> CLASS
>>>>>> COLOR 255 200 255
>>>>>> END
>>>>>> END
>>>>>> END
>>>>>> When I try to open that with my OpenLayer app, I got images with that
>>>>>> error :
>>>>>> Error: msProcessProjection(): /Projection library error/. /Invalid
>>>>>> argument
>>>>> Stella,
>>>>> I am not sure why you are getting this error. I search high and low
>>>>> and can't
>>>>> find "Invalid argument" in either MapServer or PROJ.4. Are you working
>>>>> on
>>>>> linux or Windows? Were the "/" characters really in this message? It
>>>>> is
>>>>> hard for me to understand how this could happen.
>>>>> With regard to your mapfile, I was surprised that you don't have
>>>>> wms_srs metadata on your layer. It is a shot in the dark, but perhaps
>>>>> you
>>>>> could add wms_srs EPSG:4326 metadata on the layer, and reorder the
>>>>> wms_srs
>>>>> metadata on the map to put EPSG:4326 first.
>>>>> Also, you could try changing:
>>>>> > PROJECTION
>>>>> > "proj=longlat"
>>>>> > "ellps=WGS84"
>>>>> > "datum=WGS84"
>>>>> > "no_defs"
>>>>> > END
>>>>> to:
>>>>> PROJECTION
>>>>> "+init=epsg:4326"
>>>>> END
>>>>> in both the layer and map. This is slower to expand but it might
>>>>> make it easier for mapserver to relate to epsg codes.
>>>>> Best regards,
>>>>> I set the clouds in motion - turn up | Frank Warmerdam,
>>>>> light and sound - activate the windows | http://pobox.com/~warmerdam<http://pobox.com/%7Ewarmerdam>
>>>>> and watch the world go round - Rush | Geospatial Programmer for Rent
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> mapserver-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100106/53d58bf5/attachment.html
