[mapserver-users] wms output problem
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Wed Jan 6 09:00:20 EST 2010
Mapserver can always return images at least in png, jpeg and gif formats. You must explicitly tell it what format you want with WMS &FORMAT= parameter. You can check what kind of requests the client is sending from your Apache access.log file.
-Jukka-
Valeria Muñoz wrote:
I define PNG in the mapfile.
RG
2010/1/6 Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>
> Hi,
> Are you sure you are asking for png? Your client may have a default
> setting for jpeg. The request should look like
> http://localhost/cgi-bin/mapserv.exe?map=c
> :\ms4w\osm.map&REQUEST=GetMap&SERVICE=WMS
> &VERSION=1.1.1&WIDTH=1059&HEIGHT=687&LAYERS=default&TRANSPARENT=TRUE
> &FORMAT=image/png
> &BBOX=3430775,6764522,3430932,6764624
> &SRS=epsg:2393&STYLES=
> -Jukka Rahkonen-
> Hi!
> i have a problem with the output image of my wms, i define PNG but return
> JPEG.
> Source mapfile
> OUTPUTFORMAT
> NAME png
> DRIVER "AGG/PNG"
> MIMETYPE 'image/png'
> IMAGEMODE RGB
> EXTENSION "png"
> FORMATOPTION "TRANSPARENT=OFF"
> FORMATOPTION "INTERLACE=ON"
> END
> source wms mapfile
> OUTPUTFORMAT
> NAME png
> DRIVER "AGG/PNG"
> IMAGEMODE RGB
> EXTENSION "png"
> END
> can you help me please?
> RG
