[mapserver-users] cofigure problems on Ubuntu 9.10
Vasile Cristian Stan vasileestan at gmail.com
Thu Jan 7 07:42:29 EST 2010
Thanks Alan
The packages are installed.
 ii  libjpeg62-dev  6b-14build1    Development files for the IJG JPEG
library
 ii  libpng12-dev   1.2.37-1       PNG library - development
Also, I tried  to configure using another script presented here:
http://n2.nabble.com/Error-running-configure-on-a-Linux-machine-td3278036.html#a3278036
, and with this script jpeg and png works but the rest of packages are not
included.
So, there are no problems with the packages, maybe the configuration script
is wrong.
# Vasi
Alan Boudreault wrote:
> I would suggest to verify with the dpkg command line if the packages
> |libpng12-dev and ||libjpeg62-dev |are installed.
> You can also take a look to these binarie packages:
> https://launchpad.net/~ubuntugis/+archive/ubuntugis-unstable  , which
> contain mapserver 5.6.0.
> Alan
> luftadler wrote:
>> Hi everyone,
>> I try to install MapServer 5.6.0, for the first time, on my machine
>> (using
>> Ubuntu 9.10).
>> The problem is that my configuration don't find few installed libraries
>> like: png and jpeg.
>> My configuration script:
>> ./configure \
>> --enable-debug \
>> --prefix=/usr \
>> --with-xml2 \
>> --with-pdf \
>> --with-gd \
>> --with-jpeg \
>> --with-freetype \
>> --with-agg \
>> --with-eppl \
>> --with-proj \
>> --with-threads \
>> --with-sde \
>> --with-geos \
>> --with-ogr \
>> --with-gdal \
>> --with-tiff \
>> --with-postgis \
>> --with-wfs \
>> --with-wcs \
>> --with-wmsclient \
>> --with-wfsclient \
>> --with-sos \
>> --with-fribidi-config \
>> --with-php=/usr/include/php5 \
>> --with-httpd=/usr/sbin/apache2 \
>> ______________________________________________
>> MapServer is now configured for
>>  -------------- Compiler Info -------------
>>   C compiler:                gcc -g  -fPIC -Wall
>>   C++ compiler:              g++ -g  -fPIC -Wall
>>   Debug:                     -g
>>   Generic NINT:
>>  -------------- Renderer Settings ---------
>>   OpenGL support:
>>   zlib support:              -DUSE_ZLIB
>>   png support:
>>   palette rgba png support:
>>   jpeg support:
>>   iconv support:             -DUSE_ICONV
>>   AGG support:               -DUSE_AGG
>>   Cairo (SVG,PDF) support:
>>   Ming(flash) support:
>>   PDFLib support:            -DUSE_PDF
>>  -------------- Support Libraries ---------
>>   Proj.4 support:            -DUSE_PROJ
>>   Libxml2 support:           -DUSE_LIBXML2
>>   FriBidi support:           -DUSE_FRIBIDI
>>   Curl support:              -DUSE_CURL
>>   FastCGI support:
>>   Threading support:         -DUSE_THREAD
>>   GEOS support:              -DUSE_GEOS -DGEOS_HAS_SIMPLIFY
>>  -------------- Data Format Drivers -------
>>   native tiff support:       -DUSE_TIFF
>>   PostGIS support:           -DUSE_POSTGIS
>>   EPPL7 support:             -DUSE_EPPL
>>   ArcSDE support:
>>   OGR support:               -DUSE_OGR
>>   GDAL support:              -DUSE_GDAL
>>   Oracle Spatial support:
>>  -------------- OGC Services --------------
>>   WMS Server:                -DUSE_WMS_SVR
>>   WMS Client:                -DUSE_WMS_LYR
>>   WFS Server:                -DUSE_WFS_SVR
>>   WFS Client:                -DUSE_WMS_LYR
>>   WCS Server:                -DUSE_WCS_SVR
>>   SOS Server:                -DUSE_SOS_SVR
>>  -------------- MapScript -----------------
>>   PHP MapScript:             yes
>> #Vasi
> Alan Boudreault
> Mapgears
> http://www.mapgears.com/
> mapserver-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/cofigure-problems-on-Ubuntu-9-10-tp4260091p4266229.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
