[mapserver-users] Re: Problem trying to compile Mapserver 5.6.0
with --with-experimental-png
Luigi Castro Cardeles
luigi.cardeles at gmail.com
Fri Jan 8 11:58:04 EST 2010
addon: i have the png headers installed.
[]'s
2010/1/8 Luigi Castro Cardeles <luigi.cardeles at gmail.com>
> Hi List,
> i am trying to compile Mapserver 5.6.0 on a linux box with
> --with-experimental-png but the below message appears:
> checking if AGG support requested... checking if RGBA palette png support
> requested... configure: error: cannot find png headers in
> /root/app/mapserver-5.6.0/yes
> /root/app/mapserver-5.6.0 is the folder where i untar the mapserver tarball
> yes -> i don't know what is this :P
> Where i put the location of png headers?
> This is the command line:
> ./configure --enable-point-z-m --with-freetype --with-zlib --with-png
> --with-jpeg --with-xpm --with-libiconv --with-gd --with-pdf --with-agg=/usr
> --with-experimental-png --with-eppl --with-proj --with-threads --with-geos
> --with-ogr --with-gdal --with-tiff --with-postgis --with-ming --with-wfs
> --with-wcs --with-wmsclient --with-wfsclient --with-sos --with-curl-config
> --with-xml2-config --with-fribidi-config --with-cairo --with-fastcgi
> --with-php=/usr/include/php
> If i remove --with-experimental-png, i got this:
> --with-eppl --with-proj --with-threads --with-geos --with-ogr --with-gdal
> --with-tiff --with-postgis --with-ming --with-wfs --with-wcs
> -------------- Compiler Info -------------
> C compiler: gcc -O2 -fPIC -W -Wall -Wcast-align
> -Wmissing-prototypes -Wstrict-prototypes -Wpointer-arith -Wreturn-type
> -Wmissing-declarations
> C++ compiler: g++ -O2 -fPIC -W -Wall -Wcast-align
> Debug:
> Generic NINT:
> -------------- Renderer Settings ---------
> OpenGL support:
> zlib support: -DUSE_ZLIB
> png support:
> palette rgba png support:
> jpeg support:
> iconv support: -DUSE_ICONV
> AGG support: -DUSE_AGG
> Cairo (SVG,PDF) support: -DUSE_CAIRO
> Ming(flash) support: -DUSE_MING_FLASH
> PDFLib support: -DUSE_PDF
> -------------- Support Libraries ---------
> Proj.4 support: -DUSE_PROJ
> Libxml2 support: -DUSE_LIBXML2
> FriBidi support: -DUSE_FRIBIDI -DUSE_FRIBIDI2
> Curl support: -DUSE_CURL
> FastCGI support: -DUSE_FASTCGI
> Threading support: -DUSE_THREAD
> GEOS support: -DUSE_GEOS -DGEOS_HAS_SIMPLIFY
> -------------- Data Format Drivers -------
> native tiff support: -DUSE_TIFF
> PostGIS support: -DUSE_POSTGIS
> EPPL7 support: -DUSE_EPPL
> ArcSDE support:
> OGR support: -DUSE_OGR
> GDAL support: -DUSE_GDAL
> Oracle Spatial support:
> -------------- OGC Services --------------
> WMS Server: -DUSE_WMS_SVR
> WMS Client: -DUSE_WMS_LYR
> WFS Server: -DUSE_WFS_SVR
> WFS Client: -DUSE_WMS_LYR
> WCS Server: -DUSE_WCS_SVR
> SOS Server: -DUSE_SOS_SVR
> -------------- MapScript -----------------
> PHP MapScript: yes
> Any clue about this problem?
> Best Regard's
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100108/46140bbe/attachment.html
