[mapserver-users] Premature end of script headers: mapserv
Shaz N geo.engineer123 at gmail.com
Sat Jan 9 00:27:12 EST 2010
Hi users..
I have been adding a few new shapefiles to my existing map file. I am a
facing a new problem since last evening. I added 9 shapefiles successfully
and could view the map in the browser. While adding the 10th shapefile I got
an error. All the new shapefiles are simple point shapefiles.
Example: LAYER
            NAME 'sc'
            CONNECTIONTYPE postgis
            CONNECTION " "
            DATA "the_geom from sc"
            TEMPLATE "dummy.html"
            DEBUG ON
            TYPE POINT
            MAXSCALE 10000
            MINSCALE 2000
            STATUS DEFAULT
            LABELITEM "name"
            LABELCACHE ON
            CLASS
                  MAXSCALE 10000
                  MINSCALE 2000
            STYLE
                  ANTIALIAS TRUE
                  SYMBOL "square"
                  SIZE 9
                  COLOR 153 0 102
                  OUTLINECOLOR 255 255 255
            END #end style
            LABEL
                  ANGLE auto
                  COLOR 153 0 102
                  ANTIALIAS TRUE
                  FONT vera_sans-bold
                  TYPE TRUETYPE
                  SIZE 9
                  POSITION auto
                  PARTIALS false
                  BUFFER 1
            END #end label
            END#end class
END #end layer
This is the error from the error log:
And this is what I got using WMS get map request on the browser:
Internal Server Error
The server encountered an internal error or misconfiguration and was unable
to complete your request.
Please contact the server administrator, [no address given] and inform them
of the time the error occurred, and anything you might have done that may
have caused the error.
More information about this error may be available in the server error log.
I checked the shapefile and map file for errors and couldn’t find any. And
mapserver has been installed correctly and has been working well. The
problem only arises when I add the extra layer. It works well with all the
existing ones.
The map file works on my PHP map display page but when I try it using WMS it
does not work.
I use MapServer 5.0.
Any help would be greatly appreciated.
Thanks in advance.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100109/8e3c5e5d/attachment-0001.html
