[mapserver-users] Premature end of script headers: mapserv
Dan Little
danlittle at yahoo.com
Sat Jan 9 07:45:35 EST 2010
Try testing it with shp2img and see if you still get the same error. Also, you may need to try the whole thing under GDB or with debugging turned on.
>From: Shaz N <geo.engineer123 at gmail.com>
>To: mapserver-users at lists.osgeo.org
>Sent: Fri, January 8, 2010 11:27:12 PM
>Subject: [mapserver-users] Premature end of script headers: mapserv
>Hi users..
>I have been adding a few new shapefiles to my existing map file. I am a facing a new problem since last evening. I added 9 shapefiles successfully and could view the map in the browser. While adding the 10th shapefile I got an error. All the new shapefiles are simple point shapefiles.
>Example: LAYER
> NAME 'sc'
> CONNECTIONTYPE postgis
> CONNECTION " "
> DATA "the_geom from sc"
> TEMPLATE "dummy.html"
> DEBUG ON
> TYPE POINT
> MAXSCALE 10000
> MINSCALE 2000
> STATUS DEFAULT
> LABELITEM "name"
> LABELCACHE ON
> CLASS
> MAXSCALE 10000
> MINSCALE 2000
> STYLE
> ANTIALIAS TRUE
> SYMBOL "square"
> SIZE 9
> COLOR 153 0 102
> OUTLINECOLOR 255 255 255
> END #end style
> LABEL
> ANGLE auto
> COLOR 153 0 102
> ANTIALIAS TRUE
> FONT vera_sans-bold
> TYPE TRUETYPE
> SIZE 9
> POSITION auto
> PARTIALS false
> BUFFER 1
> END #end label
> END#end class
>END #end layer
>This is the error from the error log:
>And this is what I got using WMS get map request on the browser:
>Internal Server Error
>The server encountered an internal error or misconfiguration and was unable to complete your request.
>Please contact the server administrator, [no address given] and inform them of the time the error occurred, and anything you might have done that may have caused the error.
>More information about this error may be available in the server error log.
>I checked the shapefile and map file for errors and couldn’t find any. And mapserver has been installed correctly and has been working well. The problem only arises when I add the extra layer. It works well with all the existing ones.
>The map file works on my PHP map display page but when I try it using WMS it does not work.
>I use MapServer 5.0.
>Any help would be greatly appreciated.
>Thanks in advance.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100109/824db50f/attachment-0001.html
