[mapserver-users] Premature end of script headers: mapserv
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Sat Jan 9 17:56:28 EST 2010
You talk about adding a shapefile but the layer definitions below are for PostGIS layer. Have you copy-pasted another layer or what? The main problem could be that the layer in your mail is missing entries for WMS metadata. Try reading and following the document at http://mapserver.org/ogc/wms_server.html.
-Jukka Rahkonen-
Shaz N wrote:
> Hi users..
> I have been adding a few new shapefiles to my existing map file. I am a
facing a new problem since last evening. I added 9 shapefiles successfully
and could view the map in the browser. While adding the 10th shapefile I got
an error. All the new shapefiles are simple point shapefiles.
Example: LAYER
NAME 'sc'
CONNECTIONTYPE postgis
CONNECTION " "
DATA "the_geom from sc"
TEMPLATE "dummy.html"
DEBUG ON
TYPE POINT
MAXSCALE 10000
MINSCALE 2000
STATUS DEFAULT
LABELITEM "name"
LABELCACHE ON
CLASS
MAXSCALE 10000
MINSCALE 2000
STYLE
ANTIALIAS TRUE
SYMBOL "square"
SIZE 9
COLOR 153 0 102
OUTLINECOLOR 255 255 255
END #end style
LABEL
ANGLE auto
COLOR 153 0 102
ANTIALIAS TRUE
FONT vera_sans-bold
TYPE TRUETYPE
SIZE 9
POSITION auto
PARTIALS false
BUFFER 1
END #end label
END#end class
END #end layer
This is the error from the error log:
And this is what I got using WMS get map request on the browser:
Internal Server Error
The server encountered an internal error or misconfiguration and was unable
to complete your request.
Please contact the server administrator, [no address given] and inform them
of the time the error occurred, and anything you might have done that may
have caused the error.
More information about this error may be available in the server error log.
I checked the shapefile and map file for errors and couldn't find any. And
mapserver has been installed correctly and has been working well. The
problem only arises when I add the extra layer. It works well with all the
existing ones.
The map file works on my PHP map display page but when I try it using WMS it
does not work.
I use MapServer 5.0.
Any help would be greatly appreciated.
Thanks in advance.
