[mapserver-users] Problem trying to compile Mapserver 5.6.0 with
--with-experimental-png
Luigi Castro Cardeles
luigi.cardeles at gmail.com
Mon Jan 11 11:08:00 EST 2010
Hi List,
Many thanks Daniel :D
your help was essential.
this is a test build anyway, the goal is test this features :D
[]'s
2010/1/8 Daniel Morissette <dmorissette at mapgears.com>
> Try --with-png=/usr
> You may have to provide valid paths for a few of the other configure
> options. See "./configure --help" and/or README.CONFIGURE.
> Also, it is better to turn on only the options that you require and not try
> to blindly try to include every possible options without looking up what
> they are about and which args they take.
> Daniel
> Luigi Castro Cardeles wrote:
>> Hi List,
>> i am trying to compile Mapserver 5.6.0 on a linux box with
>> --with-experimental-png but the below message appears:
>> checking if AGG support requested... checking if RGBA palette png support
>> requested... configure: error: cannot find png headers in
>> /root/app/mapserver-5.6.0/yes
>> /root/app/mapserver-5.6.0 is the folder where i untar the mapserver
>> tarball
>> yes -> i don't know what is this :P
>> Where i put the location of png headers?
>> This is the command line:
>> ./configure --enable-point-z-m --with-freetype --with-zlib --with-png
>> --with-jpeg --with-xpm --with-libiconv --with-gd --with-pdf --with-agg=/usr
>> --with-experimental-png --with-eppl --with-proj --with-threads --with-geos
>> --with-ogr --with-gdal --with-tiff --with-postgis --with-ming --with-wfs
>> --with-wcs --with-wmsclient --with-wfsclient --with-sos --with-curl-config
>> --with-xml2-config --with-fribidi-config --with-cairo --with-fastcgi
>> --with-php=/usr/include/php
>> If i remove --with-experimental-png, i got this:
>> --with-eppl --with-proj --with-threads --with-geos --with-ogr --with-gdal
>> --with-tiff --with-postgis --with-ming --with-wfs --with-wcs
>> -------------- Compiler Info -------------
>> C compiler: gcc -O2 -fPIC -W -Wall -Wcast-align
>> -Wmissing-prototypes -Wstrict-prototypes -Wpointer-arith -Wreturn-type
>> -Wmissing-declarations
>> C++ compiler: g++ -O2 -fPIC -W -Wall -Wcast-align
>> Debug: Generic NINT:
>> -------------- Renderer Settings ---------
>> OpenGL support: zlib support: -DUSE_ZLIB
>> png support: palette rgba png support: jpeg support:
>> iconv support: -DUSE_ICONV
>> AGG support: -DUSE_AGG
>> Cairo (SVG,PDF) support: -DUSE_CAIRO
>> Ming(flash) support: -DUSE_MING_FLASH
>> PDFLib support: -DUSE_PDF
>> -------------- Support Libraries ---------
>> Proj.4 support: -DUSE_PROJ
>> Libxml2 support: -DUSE_LIBXML2
>> FriBidi support: -DUSE_FRIBIDI -DUSE_FRIBIDI2
>> Curl support: -DUSE_CURL
>> FastCGI support: -DUSE_FASTCGI
>> Threading support: -DUSE_THREAD
>> GEOS support: -DUSE_GEOS -DGEOS_HAS_SIMPLIFY
>> -------------- Data Format Drivers -------
>> native tiff support: -DUSE_TIFF
>> PostGIS support: -DUSE_POSTGIS
>> EPPL7 support: -DUSE_EPPL
>> ArcSDE support: OGR support: -DUSE_OGR
>> GDAL support: -DUSE_GDAL
>> Oracle Spatial support:
>> -------------- OGC Services --------------
>> WMS Server: -DUSE_WMS_SVR
>> WMS Client: -DUSE_WMS_LYR
>> WFS Server: -DUSE_WFS_SVR
>> WFS Client: -DUSE_WMS_LYR
>> WCS Server: -DUSE_WCS_SVR
>> SOS Server: -DUSE_SOS_SVR
>> -------------- MapScript -----------------
>> PHP MapScript: yes
>> Any clue about this problem?
>> Best Regard's
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Daniel Morissette
> http://www.mapgears.com/
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100111/9a8a6f82/attachment-0001.html
