[mapserver-users] OWSRequest raw post data
Nolte, Tim Tim.Nolte at ipcswirelessinc.com
Tue Jan 12 09:56:48 EST 2010
What language are you using, is this PHP?
- Tim
Timothy J Nolte - tnolte at ilpcs.com
Network Planning Engineer
4717 Broadmoor Ave, Suite G
Kentwood, MI 49512
Office:  616-656-5163
PCS:     616-706-2438
Support: 616-929-0289
Fax:     616-554-6484
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Frank Broniewski
Sent: Tuesday, January 12, 2010 4:33 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] OWSRequest raw post data
Hello list,
I am wondering how I could load / pass a raw post body to the owsrequest
object. GET is simply done with setParameter. I see that there is a
postrequest attribute for the owsrequest object, but there is no
documentation for it. Can I set it manually? I am using a WSGI Framework and
the documented req.loadParams() function does not work with it.
Or is there a parameter 'post' or 'xml' which I can set with the raw post
data with setParameter()?
Many Thanks
Frank
Frank Broniewski
Metrico s.àr.l. ( http://www.metrico.lu )
36, rue des Romains
L-5433 Niederdonven
Luxembourg
Fon: +352 26 74 94 28
Fax: +352 26 74 94 99
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
