[mapserver-users] symbol circle (ellipse) rendered not round but
oval
Oliver Christen
oliver.christen at camptocamp.com
Wed Jan 13 04:08:24 EST 2010
thank you Thomas
so if I have a dot of, for example, 8px and I want a space pf 20px between
the dots, I need a gap of 20/8 = 2.5
but as far as I can see, Mapserver doesnt like none-integer value for gap.
what should I do? :(
2010/1/12 thomas bonfort <thomas.bonfort at gmail.com>
> gap in pixels = symbol->gap * style->size
> On Tue, Jan 12, 2010 at 16:52, Oliver Christen <
> oliver.christen at camptocamp.com> wrote:
>> GAP 20 is really giving unwanted result:
>> http://dev.camptocamp.com/~ochriste/tilecache9.png<http://dev.camptocamp.com/%7Eochriste/tilecache9.png>
>> though using only one style instead of two seems to solve the oval problem
>> (but why ???)
>> style
>> symbol "dots"
>> size 8
>> color 204 102 0
>> outlinecolor 102 51 0
>> end
>> I dont understand how GAP is supposed working:
>> with GAP 2, I had ~10px between dots,
>> with GAP 3, I had ~18px between dots,
>> with GAP 4, I had ~26px between dots
>> whats the logic ?
>> ----- Original Message -----
>> *From:* thomas bonfort <thomas.bonfort at gmail.com>
>> *To:* Oliver Christen <oliver.christen at camptocamp.com>
>> *Cc:* mapserver-users at lists.osgeo.org
>> *Sent:* Tuesday, January 12, 2010 4:36 PM
>> *Subject:* Re: [mapserver-users] symbol circle (ellipse) rendered not
>> round but oval
>> symbol
>> name dots
>> type ellipse
>> points 1 1 end
>> gap 20
>> end
>> style
>> symbol "dots"
>> size 8
>> color r g b
>> outlinecolor r g b
>> end
>> On Tue, Jan 12, 2010 at 16:31, Oliver Christen <
>>> Hi Thomas :)
>>> thanks for the answer, but sadely it didnt solve my problem:
>>> here are a few tests I did:
>>> using GAP 20 gave me really weird result:
>>> http://dev.camptocamp.com/~ochriste/tilecache6_gap_20.png<http://dev.camptocamp.com/%7Eochriste/tilecache6_gap_20.png>
>>> using PATTERN 1 22 END gave me better result, but the dot are still
>>> slightly oval:
>>> http://dev.camptocamp.com/~ochriste/tilecache7_pattern.png<http://dev.camptocamp.com/%7Eochriste/tilecache7_pattern.png>
>>> I wondered if the visual effect may have come from the fact im pilling up
>>> two circle one over the other, but even when trying to display only the
>>> outer or inner circles, the circle are still slightly off:
>>> http://dev.camptocamp.com/~ochriste/tilecache4_outercircle.png<http://dev.camptocamp.com/%7Eochriste/tilecache4_outercircle.png>
>>> http://dev.camptocamp.com/~ochriste/tilecache5_innercircle.png<http://dev.camptocamp.com/%7Eochriste/tilecache5_innercircle.png>
>>> (both at once
>>> http://dev.camptocamp.com/~ochriste/tilecache3_bothcircle.png<http://dev.camptocamp.com/%7Eochriste/tilecache3_bothcircle.png>
>>> any other idea? ^_^
>>> *Sent:* Tuesday, January 12, 2010 3:18 PM
>>> round but oval
>>> hi Oliver :)
>>> try with GAP 20 instead of STYLE 1 20 END (which is deprecated btw, use
>>> PATTERN now)
>>> cheers,
>>> thomas
>>> On Tue, Jan 12, 2010 at 15:04, Oliver Christen <
>>>> hello
>>>> I have a weird problem with symbology.
>>>> Im rendering a line with dots, but the dots are not round but slightly
>>>> oval, see image http://dev.camptocamp.com/~ochriste/tilecache.png<http://dev.camptocamp.com/%7Eochriste/tilecache.png>
>>>> Any idea what could be the cause ?
>>>> Here is my symbol definition:
>>>> SYMBOL
>>>> NAME "linie-gepunkt10"
>>>> TYPE ELLIPSE
>>>> POINTS
>>>> 1 1
>>>> END
>>>> STYLE
>>>> 1 20
>>>> END
>>>> FILLED TRUE
>>>> END
>>>> and my layer's class definition:
>>>> CLASS
>>>> EXPRESSION "3"
>>>> MAXSCALEDENOM 200001
>>>> STYLE
>>>> SYMBOL "linie-gepunkt10"
>>>> SIZE 10
>>>> COLOR 102 51 0
>>>> END
>>>> STYLE
>>>> SIZE 8
>>>> COLOR 204 102 0
>>>> END
>>>> END
>>>> and the map outputformat:
>>>> OUTPUTFORMAT
>>>> NAME png
>>>> DRIVER "AGG/PNG"
>>>> MIMETYPE "image/png"
>>>> IMAGEMODE RGBA
>>>> EXTENSION "png"
>>>> FORMATOPTION "INTERLACE=OFF"
>>>> END
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100113/65545eef/attachment-0001.html
