[mapserver-users] php error
Alan Boudreault aboudreault at mapgears.com
Wed Jan 13 18:47:00 EST 2010
You can have both on your system, but if you want to use php mapscript
with php 5.2.9, you need to specify the proper header path.
ie. on ubuntu:
--with-php=/usr/include/php5/
This way, the mapscript module will work with your php 5.2.9.
Hope this help.
Alan
bascom49 wrote:
> Alan Boudreault wrote:
>> PHP mapscript hasn't been compiled with php 5.2.9. You'll have to
>> rebuild the module with the proper php lib. You probably have a old php
>> 4.x on your system too.
>> Alan
>> bascom49 wrote:
>>> I am installing mapserver 5.4.2. My php version is 5.2.9.
>>> I am getting an error message with the following code :
>>> php
>>> if (PHP_OS == "WINNT" || PHP_OS == "WIN32") {
>>>             $dllversion = 'php_mapscript.dll';
>>> } else {
>>>             $dllversion = 'php_mapscript.so';
>>> if (!extension_loaded('MapScript')) {dl($dllversion);}
>>> phpinfo();
>>> A link to the file producing this error is at :
>>> http://174.120.238.19/info.php
>>> You can view my php configuration at this link:
>>> Does anyone have experience with the following php issue ?
>>> [13-Jan-2010 14:00:04] PHP Warning:  PHP Startup: Unable to load dynamic
>>> library
>>> '/usr/local/lib/php/extensions/no-debug-non-zts-20060613/âphp_mapscript.soâphp_mapscript.soâ
>>> PHP
>>> Warning:  PHP Startup: UõSHìè: Unable to initialize module
>>> Module compiled with module API=20020429, debug=0, thread-safety=0
>>> PHP    compiled with module API=20060613, debug=0, thread-safety=0
>>> These options need to match
>>> Thanks,
>>> Charles
>> Alan Boudreault
>> Mapgears
>> http://www.mapgears.com/
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> I had installing mapscript with php by following this link:
> http://mapserver.org/installation/php.html
> and must have misunderstood that I could compile against
> php5. I do have a php4 binary on my server. Is this as simple as
> compiling mapserver with the php4 binary to produce php_mapscript.so
> and keeping php5 on my system or do I have to reinstall php4 as well ?
Alan Boudreault
Mapgears
