[mapserver-users] OWSRequest raw post data
Frank Broniewski
brfr at metrico.lu
Thu Jan 14 01:42:39 EST 2010
It seems that setting owsrequest.postdata is sufficiant
Sent: Tuesday, January 12, 2010 4:26 PM
To: <mapserver-users at lists.osgeo.org>
Subject: Re: [mapserver-users] OWSRequest raw post data
> Sorry, I forgot to mention that. I'm using Python ...
> From: "Nolte, Tim" <Tim.Nolte at ipcswirelessinc.com>
> Sent: Tuesday, January 12, 2010 3:56 PM
> To: "Frank Broniewski" <brfr at metrico.lu>;
> Subject: RE: [mapserver-users] OWSRequest raw post data
>> What language are you using, is this PHP?
>> - Tim
>> Timothy J Nolte - tnolte at ilpcs.com
>> Network Planning Engineer
>> 4717 Broadmoor Ave, Suite G
>> Kentwood, MI 49512
>> Office: 616-656-5163
>> PCS: 616-706-2438
>> Support: 616-929-0289
>> Fax: 616-554-6484
>> -----Original Message-----
>> From: mapserver-users-bounces at lists.osgeo.org
>> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Frank
>> Broniewski
>> Sent: Tuesday, January 12, 2010 4:33 AM
>> To: mapserver-users at lists.osgeo.org
>> Subject: [mapserver-users] OWSRequest raw post data
>> Hello list,
>> I am wondering how I could load / pass a raw post body to the owsrequest
>> object. GET is simply done with setParameter. I see that there is a
>> postrequest attribute for the owsrequest object, but there is no
>> documentation for it. Can I set it manually? I am using a WSGI Framework
>> and
>> the documented req.loadParams() function does not work with it.
>> Or is there a parameter 'post' or 'xml' which I can set with the raw post
>> data with setParameter()?
>> Many Thanks
>> Frank
>> Frank Broniewski
>> Metrico s.àr.l. ( http://www.metrico.lu )
>> 36, rue des Romains
>> L-5433 Niederdonven
>> Luxembourg
>> Fon: +352 26 74 94 28
>> Fax: +352 26 74 94 99
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
