[mapserver-users] symbol circle (ellipse) rendered not round but oval
Oliver Christen oliver.christen at camptocamp.com
Thu Jan 14 03:22:57 EST 2010
mmm, I tested a bit and it seems the calculation is more complex than that, as the ellipse size definition of the symbol has also some effect.
style->size 8, "points 6 6 end", "gap 20" => spacing of ~20px between dots
style->size 8, "points 8 8 end", "gap 20" => spacing of ~14px between dots
style->size 10, "points 6 6 end", "gap 20" => spacing of ~26px between dots
I fear I dont understand at all how this is calculated :(
  ----- Original Message -----
  To: thomas bonfort
  Cc: mapserver-users at lists.osgeo.org
  Sent: Wednesday, January 13, 2010 10:08 AM
  Subject: Re: [mapserver-users] symbol circle (ellipse) rendered not round but oval
  thank you Thomas
  so if I have a dot of, for example, 8px and I want a space pf 20px between the dots, I need a gap of 20/8 =  2.5
  but as far as I can see, Mapserver doesnt like none-integer value for gap.
  what should I do? :(
  2010/1/12 thomas bonfort <thomas.bonfort at gmail.com>
    gap in pixels = symbol->gap * style->size
    On Tue, Jan 12, 2010 at 16:52, Oliver Christen <oliver.christen at camptocamp.com> wrote:
      GAP 20 is really giving unwanted result:
      http://dev.camptocamp.com/~ochriste/tilecache9.png
      though using only one style instead of two seems to solve the oval problem (but why ???)
          style
           symbol "dots"
           size 8
           color 204 102 0
           outlinecolor  102 51 0
          end
      I dont understand how GAP is supposed working:
      with GAP 2, I had ~10px between dots,
      with GAP 3, I had ~18px between dots,
      with GAP 4, I had ~26px between dots
      whats the logic ?
        To: Oliver Christen
        Sent: Tuesday, January 12, 2010 4:36 PM
        symbol
         name dots
         type ellipse
         points 1 1 end
         gap 20
        end
        style
         symbol "dots"
         size 8
         color r g b
         outlinecolor  r g b
        end
        On Tue, Jan 12, 2010 at 16:31, Oliver Christen <oliver.christen at camptocamp.com> wrote:
          Hi Thomas :)
          thanks for the answer, but sadely it didnt solve my problem:
          here are a few tests I did:
          using GAP 20 gave me really weird result:
          http://dev.camptocamp.com/~ochriste/tilecache6_gap_20.png
          using PATTERN 1 22 END gave me better result, but the dot are still slightly oval:
          http://dev.camptocamp.com/~ochriste/tilecache7_pattern.png
          I wondered if the visual effect may have come from the fact im pilling up two circle one over the other, but even when trying to display only the outer or inner circles, the circle are still slightly off:
          http://dev.camptocamp.com/~ochriste/tilecache4_outercircle.png
          http://dev.camptocamp.com/~ochriste/tilecache5_innercircle.png
          (both at once http://dev.camptocamp.com/~ochriste/tilecache3_bothcircle.png)
          any other idea? ^_^
            To: Oliver Christen
            Sent: Tuesday, January 12, 2010 3:18 PM
            hi Oliver :)
            try with GAP 20 instead of STYLE 1 20 END (which is deprecated btw, use PATTERN now)
            cheers,
            thomas
            On Tue, Jan 12, 2010 at 15:04, Oliver Christen <oliver.christen at camptocamp.com> wrote:
              hello
              I have a weird problem with symbology.
              Im rendering a line with dots, but the dots are not round but slightly oval, see image http://dev.camptocamp.com/~ochriste/tilecache.png
              Any idea what could be the cause ?
              Here is my symbol definition:
              SYMBOL
               NAME "linie-gepunkt10"
               TYPE ELLIPSE
               POINTS
                1 1
               END
               STYLE
                1 20
               END
               FILLED TRUE
              END
              and my layer's class definition:
               CLASS
                EXPRESSION "3"
                MAXSCALEDENOM 200001
                STYLE
                  SYMBOL "linie-gepunkt10"
                  SIZE 10
                  COLOR 102 51 0
                END
                STYLE
                  SIZE 8
                  COLOR 204 102 0
                END
               END
              and the map outputformat:
              OUTPUTFORMAT
               NAME png
               DRIVER "AGG/PNG"
               MIMETYPE "image/png"
               IMAGEMODE RGBA
               EXTENSION "png"
               FORMATOPTION "INTERLACE=OFF"
              END
              mapserver-users mailing list
              http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100114/fc52afd6/attachment-0001.html
