[mapserver-users] symbol circle (ellipse) rendered not round but oval
Havard Tveite havard.tveite at umb.no
Thu Jan 14 11:26:12 EST 2010
If Thomas B. agrees, I think it would be reasonable to also
open a bug on the gap calculation.
In my opinion, since the word "gap" is used, the correct
way to specify a symbol with ellipses that has the same
gap between them as the diameter of the ellipses should be
as follows:
symbol
   name dots
   type ellipse
   points 1 1 end
   gap 1
end
or an equivalent "scaled" version such as:
symbol
   name dots
   type ellipse
   points 23 23 end
   gap 23
end
The actual size of the ellipses (and the width of the gaps)
should be determined by the SIZE in CLASS-> STYLE.  If
SIZE is 10, the ellipses should have a 10 pixel diameter
(and should have a 10 pixel gap between them).
I have been hesitant to file bugs regarding symbology, since
the documentation on symbology is lacking and there is not
complete agreement on how some of the things that has to do
with symbology should work.  There have also been
discussions on changing some behaviour and mechanisms for
symbology.
First we have to agree on how things should work and document
it, then we can file bugs if behaviour is not as expected.
Håvard
Oliver Christen wrote:
> Hi Steve
> I followed your suggestion and opened a documentation bug
> thanks
> Oliver
>> Hi guys,
>> I haven't followed this whole thread but I think it should be better
>> documented so people can understand how to use this. Please write a doc
>> bug and put as much information in the bug about how this works as you
>> have been able to discover.
>> Thanks,
>>   -Steve W
>>> Thank you Håvard
>>> I see you have changed "points 1 1 end" by "points 8 8 end".
>>> Tell me if im wrong, but these values are only used to render the
>>> proportions of the elipse but not it's size, is that correct?
>>> so if I understand correctly, using larger values for the elipse
>>> width/height refine the rendering of the vectorised dot geometry ?
>>> regards
>>> Oliver
>>>> Dear Oliver Christen,
>>>> Using Mapserver 5.6.0 and AGG rendering, you can achieve what
>>>> you want by using a combination of ellipse size and gap size
>>>> in the symbol definition.
>>>> There is something strange in the calculations (a gap of
>>>> about half the ellipse size seems to produce touching symbols),
>>>> so in your case, you could try to use 8 as the diameter of the
>>>> ellipses, and 20 + 4 (half the ellipse size) = 24 as the
>>>> gap:
>>>> symbol
>>>>  name dots
>>>>  type ellipse
>>>>  points 8 8 end
>>>>  gap 24
>>>> end
>>>> Håvard
>>>>> thank you Thomas
>>>>> so if I have a dot of, for example, 8px and I want a space pf 20px
>>>>> between the dots, I need a gap of 20/8 =  2.5
>>>>> but as far as I can see, Mapserver doesnt like none-integer value for
>>>>> gap.
>>>>> what should I do? :(
>>>>> 2010/1/12 thomas bonfort <thomas.bonfort at gmail.com
>>>>> <mailto:thomas.bonfort at gmail.com>>
>>>>>     gap in pixels = symbol->gap * style->size
>>>>>     On Tue, Jan 12, 2010 at 16:52, Oliver Christen
>>>>>     <oliver.christen at camptocamp.com
>>>>>     <mailto:oliver.christen at camptocamp.com>> wrote:
>>>>>         GAP 20 is really giving unwanted result:
>>>>>          http://dev.camptocamp.com/~ochriste/tilecache9.png
>>>>>         <http://dev.camptocamp.com/%7Eochriste/tilecache9.png>
>>>>>          though using only one style instead of two seems to solve the
>>>>>         oval problem (but why ???)
>>>>>          style
>>>>>              symbol "dots"
>>>>>              size 8
>>>>>              color 204 102 0
>>>>>              outlinecolor  102 51 0
>>>>>             end
>>>>>          I dont understand how GAP is supposed working:
>>>>>          with GAP 2, I had ~10px between dots,
>>>>>         with GAP 3, I had ~18px between dots,
>>>>>         with GAP 4, I had ~26px between dots
>>>>>          whats the logic ?
>>>>>             ----- Original Message -----
>>>>>             *From:* thomas bonfort <mailto:thomas.bonfort at gmail.com>
>>>>>             *To:* Oliver Christen
>>>>>             *Cc:* mapserver-users at lists.osgeo.org
>>>>>             <mailto:mapserver-users at lists.osgeo.org>
>>>>>             *Sent:* Tuesday, January 12, 2010 4:36 PM
>>>>>             *Subject:* Re: [mapserver-users] symbol circle (ellipse)
>>>>>             symbol
>>>>>              name dots
>>>>>              type ellipse
>>>>>              points 1 1 end
>>>>>              gap 20
>>>>>             end
>>>>>             style
>>>>>              symbol "dots"
>>>>>              size 8
>>>>>              color r g b
>>>>>              outlinecolor  r g b
>>>>>             end
>>>>>             On Tue, Jan 12, 2010 at 16:31, Oliver Christen
>>>>>                 Hi Thomas :)
>>>>>                  thanks for the answer, but sadely it didnt solve my
>>>>> problem:
>>>>>                  here are a few tests I did:
>>>>>                  using GAP 20 gave me really weird result:
>>>>> http://dev.camptocamp.com/~ochriste/tilecache6_gap_20.png
>>>>> <http://dev.camptocamp.com/%7Eochriste/tilecache6_gap_20.png>
>>>>>                  using PATTERN 1 22 END gave me better result, but the
>>>>>                 dot are still slightly oval:
>>>>> http://dev.camptocamp.com/~ochriste/tilecache7_pattern.png
>>>>> <http://dev.camptocamp.com/%7Eochriste/tilecache7_pattern.png>
>>>>>                  I wondered if the visual effect may have come from the
>>>>>                 fact im pilling up two circle one over the other, but
>>>>>                 even when trying to display only the outer or inner
>>>>>                 circles, the circle are still slightly off:
>>>>> http://dev.camptocamp.com/~ochriste/tilecache4_outercircle.png
>>>>> <http://dev.camptocamp.com/%7Eochriste/tilecache4_outercircle.png>
>>>>> http://dev.camptocamp.com/~ochriste/tilecache5_innercircle.png
>>>>> <http://dev.camptocamp.com/%7Eochriste/tilecache5_innercircle.png>
>>>>>                 (both at once
>>>>> http://dev.camptocamp.com/~ochriste/tilecache3_bothcircle.png
>>>>> <http://dev.camptocamp.com/%7Eochriste/tilecache3_bothcircle.png>)
>>>>>                  any other idea? ^_^
>>>>>                     *Sent:* Tuesday, January 12, 2010 3:18 PM
>>>>>                     hi Oliver :)
>>>>>                     try with GAP 20 instead of STYLE 1 20 END (which is
>>>>>                     deprecated btw, use PATTERN now)
>>>>>                     cheers,
>>>>>                     thomas
>>>>>                     On Tue, Jan 12, 2010 at 15:04, Oliver Christen
>>>>>                         hello
>>>>>                         I have a weird problem with symbology.
>>>>>                         Im rendering a line with dots, but the dots are
>>>>>                         not round but slightly oval, see image
>>>>> http://dev.camptocamp.com/~ochriste/tilecache.png
>>>>> <http://dev.camptocamp.com/%7Eochriste/tilecache.png>
>>>>>                         Any idea what could be the cause ?
>>>>>                         Here is my symbol definition:
>>>>>                         SYMBOL
>>>>>                          NAME "linie-gepunkt10"
>>>>>                          TYPE ELLIPSE
>>>>>                          POINTS
>>>>>                           1 1
>>>>>                          END
>>>>>                          STYLE
>>>>>                           1 20
>>>>>                          END
>>>>>                          FILLED TRUE
>>>>>                         END
>>>>>                         and my layer's class definition:
>>>>>                          CLASS
>>>>>                           EXPRESSION "3"
>>>>>                           MAXSCALEDENOM 200001
>>>>>                           STYLE
>>>>>                             SYMBOL "linie-gepunkt10"
>>>>>                             SIZE 10
>>>>>                             COLOR 102 51 0
>>>>>                           END
>>>>>                           STYLE
>>>>>                             SIZE 8
>>>>>                             COLOR 204 102 0
>>>>>                           END
>>>>>                          END
>>>>>                         and the map outputformat:
>>>>>                         OUTPUTFORMAT
>>>>>                          NAME png
>>>>>                          DRIVER "AGG/PNG"
>>>>>                          MIMETYPE "image/png"
>>>>>                          IMAGEMODE RGBA
>>>>>                          EXTENSION "png"
>>>>>                          FORMATOPTION "INTERLACE=OFF"
>>>>>                         END
>>>>>                         _______________________________________________
>>>>>                         mapserver-users mailing list
>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>>>> Håvard Tveite
>>>> Department of Mathematical Sciences and Technology, UMB
>>>> Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
>>>> Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
Håvard Tveite
