[mapserver-users] MapServer with JBOSS
Dave Potts
dave.potts at pinan.co.uk
Thu Jan 14 14:51:12 EST 2010
Flavio Souza wrote:
Yes its possible but there are problem depending on your platform type.
Jboss expects everything to be packaged up as a jar file, when these are
expanded on a Linux/Unix system, set to mode 644, ie rw for owner and
readable for everybody else. Since the map server program is a binary,
after jboss has deployed your mapserver application, you must manual
turn the execute bit on. The problem is finding out where jboss has
place your application.
You also have to enabled the cgi setting for the tomcat process, its
burried away in one of the many xml files.
> Hello again
> Anyone knows if is it possible , to use MapServer with JBOSS ?
> Thanks in advance
> Flávio Souza
> _______________________________
> Flávio Souza
> (021) 7629-4249
> mapserver-users at lists.osgeo.org
