[mapserver-users] symbol circle (ellipse) rendered not round but oval
Havard Tveite havard.tveite at umb.no
Fri Jan 15 03:05:15 EST 2010
I think it is very important that there is a strong
relationship between the size of the symbols and the
spacing between the symbols.  That makes scalable
patterned symbols possible.  So I am happy with the
current (intended) behaviour.
What is needed is good documentation with examples.  I
think that there is work in progress on changing some of
the mechanisms for symbology in Mapserver.  When this
work has been "finalised" I will be more than willing
to contribute to the documentation.
Håvard
Oliver Christen wrote:
> mmm, in my opinion it would be clearer if the GAP didnt depend from
> anything, set the GAP to 10 would make you a spacing of 10px between each
> symbols border, whatever the values of the symbol POINTS.
> but that may be a change too important ?
> Oliver
>> Stephen Woodbridge wrote:
>>> So if I want ten pixel ellipses with a 1, 2, or 3 pixels gap how would
>>> you specify that?
>>> points 10 10 gap 1 (or 2 or 3)?
>> Yes, if the rendering behaviour had been according to my
>> preferences,
>> POINTS 10 10 END
>> GAP 1 (or 2 or 3)
>> should do it (if you had specified SIZE 10 in the STYLE).
>> You specify the gap, and not the centre to centre distance
>> between the ellipses.
>> But currently, this is not the behaviour.
>> Currently (with AGG in 5.6.0) you would have to specify:
>> POINTS 10 10 END
>> GAP 6 (or 7 or 8)
>> to get something close (if you specify SIZE 10 in the STYLE).
>> Something seems to be wrong when the GAP is close to
>> half the diameter specified in POINTS - some of the gaps
>> will be as expected, while others are larger (closer to the
>> actual number specified in GAP).
>> Håvard
>>> -Steve W
>>> Havard Tveite wrote:
>>>> If Thomas B. agrees, I think it would be reasonable to also
>>>> open a bug on the gap calculation.
>>>> In my opinion, since the word "gap" is used, the correct
>>>> way to specify a symbol with ellipses that has the same
>>>> gap between them as the diameter of the ellipses should be
>>>> as follows:
>>>> symbol
>>>>   name dots
>>>>   type ellipse
>>>>   points 1 1 end
>>>>   gap 1
>>>> end
>>>> or an equivalent "scaled" version such as:
>>>> symbol
>>>>   name dots
>>>>   type ellipse
>>>>   points 23 23 end
>>>>   gap 23
>>>> end
>>>> The actual size of the ellipses (and the width of the gaps)
>>>> should be determined by the SIZE in CLASS-> STYLE.  If
>>>> SIZE is 10, the ellipses should have a 10 pixel diameter
>>>> (and should have a 10 pixel gap between them).
>>>> I have been hesitant to file bugs regarding symbology, since
>>>> the documentation on symbology is lacking and there is not
>>>> complete agreement on how some of the things that has to do
>>>> with symbology should work.  There have also been
>>>> discussions on changing some behaviour and mechanisms for
>>>> symbology.
>>>> First we have to agree on how things should work and document
>>>> it, then we can file bugs if behaviour is not as expected.
>>>> Håvard
>>>>> Hi Steve
>>>>> I followed your suggestion and opened a documentation bug
>>>>> thanks
>>>>> Oliver
>>>>>> Hi guys,
>>>>>> I haven't followed this whole thread but I think it should be better
>>>>>> documented so people can understand how to use this. Please write a
>>>>>> doc bug and put as much information in the bug about how this works as
>>>>>> you have been able to discover.
>>>>>> Thanks,
>>>>>>   -Steve W
>>>>>>> Thank you Håvard
>>>>>>> I see you have changed "points 1 1 end" by "points 8 8 end".
>>>>>>> Tell me if im wrong, but these values are only used to render the
>>>>>>> proportions of the elipse but not it's size, is that correct?
>>>>>>> so if I understand correctly, using larger values for the elipse
>>>>>>> width/height refine the rendering of the vectorised dot geometry ?
>>>>>>> regards
>>>>>>> Oliver
>>>>>>>> Dear Oliver Christen,
>>>>>>>> Using Mapserver 5.6.0 and AGG rendering, you can achieve what
>>>>>>>> you want by using a combination of ellipse size and gap size
>>>>>>>> in the symbol definition.
>>>>>>>> There is something strange in the calculations (a gap of
>>>>>>>> about half the ellipse size seems to produce touching symbols),
>>>>>>>> so in your case, you could try to use 8 as the diameter of the
>>>>>>>> ellipses, and 20 + 4 (half the ellipse size) = 24 as the
>>>>>>>> gap:
>>>>>>>> symbol
>>>>>>>>  name dots
>>>>>>>>  type ellipse
>>>>>>>>  points 8 8 end
>>>>>>>>  gap 24
>>>>>>>> end
>>>>>>>> Håvard
>>>>>>>>> thank you Thomas
>>>>>>>>> so if I have a dot of, for example, 8px and I want a space pf 20px
>>>>>>>>> between the dots, I need a gap of 20/8 =  2.5
>>>>>>>>> but as far as I can see, Mapserver doesnt like none-integer value
>>>>>>>>> for gap.
>>>>>>>>> what should I do? :(
>>>>>>>>> 2010/1/12 thomas bonfort <thomas.bonfort at gmail.com
>>>>>>>>> <mailto:thomas.bonfort at gmail.com>>
>>>>>>>>>     gap in pixels = symbol->gap * style->size
>>>>>>>>>     On Tue, Jan 12, 2010 at 16:52, Oliver Christen
>>>>>>>>>     <oliver.christen at camptocamp.com
>>>>>>>>>     <mailto:oliver.christen at camptocamp.com>> wrote:
>>>>>>>>>         GAP 20 is really giving unwanted result:
>>>>>>>>>          http://dev.camptocamp.com/~ochriste/tilecache9.png
>>>>>>>>>         <http://dev.camptocamp.com/%7Eochriste/tilecache9.png>
>>>>>>>>>          though using only one style instead of two seems to solve
>>>>>>>>> the
>>>>>>>>>         oval problem (but why ???)
>>>>>>>>>          style
>>>>>>>>>              symbol "dots"
>>>>>>>>>              size 8
>>>>>>>>>              color 204 102 0
>>>>>>>>>              outlinecolor  102 51 0
>>>>>>>>>             end
>>>>>>>>>          I dont understand how GAP is supposed working:
>>>>>>>>>          with GAP 2, I had ~10px between dots,
>>>>>>>>>         with GAP 3, I had ~18px between dots,
>>>>>>>>>         with GAP 4, I had ~26px between dots
>>>>>>>>>          whats the logic ?
>>>>>>>>>             ----- Original Message -----
>>>>>>>>>             *From:* thomas bonfort
>>>>>>>>>             *To:* Oliver Christen
>>>>>>>>>             *Cc:* mapserver-users at lists.osgeo.org
>>>>>>>>>             <mailto:mapserver-users at lists.osgeo.org>
>>>>>>>>>             *Sent:* Tuesday, January 12, 2010 4:36 PM
>>>>>>>>>             *Subject:* Re: [mapserver-users] symbol circle
>>>>>>>>> (ellipse)
>>>>>>>>>             symbol
>>>>>>>>>              name dots
>>>>>>>>>              type ellipse
>>>>>>>>>              points 1 1 end
>>>>>>>>>              gap 20
>>>>>>>>>             end
>>>>>>>>>             style
>>>>>>>>>              symbol "dots"
>>>>>>>>>              size 8
>>>>>>>>>              color r g b
>>>>>>>>>              outlinecolor  r g b
>>>>>>>>>             end
>>>>>>>>>             On Tue, Jan 12, 2010 at 16:31, Oliver Christen
>>>>>>>>>                 Hi Thomas :)
>>>>>>>>>                  thanks for the answer, but sadely it didnt solve
>>>>>>>>> my problem:
>>>>>>>>>                  here are a few tests I did:
>>>>>>>>>                  using GAP 20 gave me really weird result:
>>>>>>>>> http://dev.camptocamp.com/~ochriste/tilecache6_gap_20.png
>>>>>>>>> <http://dev.camptocamp.com/%7Eochriste/tilecache6_gap_20.png>
>>>>>>>>>                  using PATTERN 1 22 END gave me better result, but
>>>>>>>>> the
>>>>>>>>>                 dot are still slightly oval:
>>>>>>>>> http://dev.camptocamp.com/~ochriste/tilecache7_pattern.png
>>>>>>>>> <http://dev.camptocamp.com/%7Eochriste/tilecache7_pattern.png>
>>>>>>>>>                  I wondered if the visual effect may have come from
>>>>>>>>> the
>>>>>>>>>                 fact im pilling up two circle one over the other,
>>>>>>>>> but
>>>>>>>>>                 even when trying to display only the outer or inner
>>>>>>>>>                 circles, the circle are still slightly off:
>>>>>>>>> http://dev.camptocamp.com/~ochriste/tilecache4_outercircle.png
>>>>>>>>> <http://dev.camptocamp.com/%7Eochriste/tilecache4_outercircle.png>
>>>>>>>>> http://dev.camptocamp.com/~ochriste/tilecache5_innercircle.png
>>>>>>>>> <http://dev.camptocamp.com/%7Eochriste/tilecache5_innercircle.png>
>>>>>>>>>                 (both at once
>>>>>>>>> http://dev.camptocamp.com/~ochriste/tilecache3_bothcircle.png
>>>>>>>>> <http://dev.camptocamp.com/%7Eochriste/tilecache3_bothcircle.png>)
>>>>>>>>>                  any other idea? ^_^
>>>>>>>>>                     *Sent:* Tuesday, January 12, 2010 3:18 PM
>>>>>>>>>                     hi Oliver :)
>>>>>>>>>                     try with GAP 20 instead of STYLE 1 20 END
>>>>>>>>> (which is
>>>>>>>>>                     deprecated btw, use PATTERN now)
>>>>>>>>>                     cheers,
>>>>>>>>>                     thomas
>>>>>>>>>                     On Tue, Jan 12, 2010 at 15:04, Oliver Christen
>>>>>>>>>                         hello
>>>>>>>>>                         I have a weird problem with symbology.
>>>>>>>>>                         Im rendering a line with dots, but the dots
>>>>>>>>> are
>>>>>>>>>                         not round but slightly oval, see image
>>>>>>>>> http://dev.camptocamp.com/~ochriste/tilecache.png
>>>>>>>>> <http://dev.camptocamp.com/%7Eochriste/tilecache.png>
>>>>>>>>>                         Any idea what could be the cause ?
>>>>>>>>>                         Here is my symbol definition:
>>>>>>>>>                         SYMBOL
>>>>>>>>>                          NAME "linie-gepunkt10"
>>>>>>>>>                          TYPE ELLIPSE
>>>>>>>>>                          POINTS
>>>>>>>>>                           1 1
>>>>>>>>>                          END
>>>>>>>>>                          STYLE
>>>>>>>>>                           1 20
>>>>>>>>>                          END
>>>>>>>>>                          FILLED TRUE
>>>>>>>>>                         END
>>>>>>>>>                         and my layer's class definition:
>>>>>>>>>                          CLASS
>>>>>>>>>                           EXPRESSION "3"
>>>>>>>>>                           MAXSCALEDENOM 200001
>>>>>>>>>                           STYLE
>>>>>>>>>                             SYMBOL "linie-gepunkt10"
>>>>>>>>>                             SIZE 10
>>>>>>>>>                             COLOR 102 51 0
>>>>>>>>>                           END
>>>>>>>>>                           STYLE
>>>>>>>>>                             SIZE 8
>>>>>>>>>                             COLOR 204 102 0
>>>>>>>>>                           END
>>>>>>>>>                          END
>>>>>>>>>                         and the map outputformat:
>>>>>>>>>                         OUTPUTFORMAT
>>>>>>>>>                          NAME png
>>>>>>>>>                          DRIVER "AGG/PNG"
>>>>>>>>>                          MIMETYPE "image/png"
>>>>>>>>>                          IMAGEMODE RGBA
>>>>>>>>>                          EXTENSION "png"
>>>>>>>>>                          FORMATOPTION "INTERLACE=OFF"
>>>>>>>>>                         END
>>>>>>>>> _______________________________________________
>>>>>>>>>                         mapserver-users mailing list
>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>>>>>>>> Håvard Tveite
>>>>>>>> Department of Mathematical Sciences and Technology, UMB
>>>>>>>> Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
>>>>>>>> Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
>> Håvard Tveite
Håvard Tveite
