[mapserver-users] symbol at start and end of polyline ?
thomas bonfort thomas.bonfort at gmail.com
Tue Jan 19 08:10:38 EST 2010
if you're using postgis, you can use a unique key from your table (i.e. gid)
if you have a shapefile, you'll have to find an or a combination of
attributes in the dbf that's unique to identify that particular feature.
thomas
On Tue, Jan 19, 2010 at 11:59, Oliver Christen <
oliver.christen at camptocamp.com> wrote:
>  it makes sens, but how do I do that ?
> do line segment get automaticaly an id ?
> or how to get (or set) the id of the line segment?
> ----- Original Message -----
> *From:* thomas bonfort <thomas.bonfort at gmail.com>
> *To:* Oliver Christen <oliver.christen at camptocamp.com>
> *Cc:* mapserver-users at lists.osgeo.org
> *Sent:* Tuesday, January 19, 2010 10:50 AM
> *Subject:* Re: [mapserver-users] symbol at start and end of polyline ?
> well, if you want only one line segment to have start markers, you must
> tell mapserver which segment that is.
> On Tue, Jan 19, 2010 at 10:48, Oliver Christen <
>>  thx Thomas, but im not sure I understand what you are telling me here.
>> do line segments have id ?
>> *Sent:* Tuesday, January 19, 2010 10:30 AM
>> hi,
>> class
>>   expression ([id]=321)
>>   style
>>     geomtransform end
>>   end
>> end
>> class
>>   style
>>     ... #all the others
>>   end
>> end
>> On Tue, Jan 19, 2010 at 10:14, Oliver Christen <
>>> hello
>>> I would like to add a symbol at the start and end of a polyline.
>>> I tried using GEOMTRANSFORM with "start" and "end" in a style block in
>>> the layer but sadely this will add a symbol to all start and end of every
>>> vertex of the polyline, which is not the result wanted :/
>>> is there any way to do that, beside creating a new point layer ?
>>> thanks in advance
>>> Oliver
>>> mapserver-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100119/90b0d767/attachment.html
