[mapserver-users] RE: Images returning blank
Fawcett, David (MPCA)
David.Fawcett at state.mn.us
Tue Jan 19 16:27:45 EST 2010
Based on the errors, it looks like you will need EXTENT to your map file at the MAP level.
What do you get when you run ogrinfo against the two shapefiles? Any difference?
Are you adding a URL var for the layer name? Try setting LAYER STATUS to DEFAULT for both layers and see if you get an image back.
David.
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Kent Morrison
Sent: Tuesday, January 19, 2010 3:17 PM
To: 'mapserver-users at lists.osgeo.org'
Subject: [mapserver-users] Images returning blank
I have mapserver 5.4.2 installed.
I have two different shape files, one renders properly the other only returns blank images
The debug log for the one that does not work returns:
[Tue Jan 19 20:34:59 2010].212000 CGI Request 1 on process 1180
[Tue Jan 19 20:34:59 2010].212000 mapserv(): Web application error. No way to generate map extent.
[Tue Jan 19 20:34:59 2010].212000 msCalculateScale(): General error message. Invalid image extent, minx=-1.000000, miny=-1.000000, maxx=-1.000000, maxy=-1.000000.
[Tue Jan 19 20:34:59 2010].212000 msTileSetExtent (-13090872.991896, 6046512.903143) (-13071381.549686, 6066004.345353)
[Tue Jan 19 20:34:59 2010].227000 msDrawMap(): Layer 0 (SpokaneTrafficFlows), 0.000s
[Tue Jan 19 20:34:59 2010].227000 msDrawMap(): Drawing Label Cache, 0.000s
[Tue Jan 19 20:34:59 2010].227000 msDrawMap() total time: 0.015s
[Tue Jan 19 20:34:59 2010].274000 msSaveImage() total time: 0.047s
[Tue Jan 19 20:34:59 2010].274000 mapserv request processing time (loadmap not incl.): 0.062s
[Tue Jan 19 20:34:59 2010].274000 msFreeMap(): freeing map at 01A5AF00.
[Tue Jan 19 20:34:59 2010].274000 freeLayer(): freeing layer at 020E4160.
the map file is:
MAP
IMAGETYPE AGG
SIZE 256 256
SHAPEPATH "/MapServerData/ShapeFiles/1"
IMAGECOLOR 255 255 255
TRANSPARENT ON
FONTSET "../../fonts/fonts.list"
CONFIG PROJ_LIB "c:\ms4w\proj\nad\"
CONFIG MS_ERRORFILE "c:\ms4w\tmp\errors2.txt"
DEBUG 5
PROJECTION
"init=epsg:4326"
END
OUTPUTFORMAT
NAME 'AGG'
DRIVER AGG/PNG
IMAGEMODE RGB
END #Outputformat
LAYER
NAME SpokaneTrafficFlows
DATA TrafficFlow_2007
STATUS ON
TYPE LINE
DEBUG 5
CLASS
NAME "classSpokaneTrafficFlows"
STYLE
COLOR 127 255 64
OPACITY 50
OUTLINECOLOR 255 128 64
WIDTH 3
END #style
END #class
END #layer
END #Map
running shp2img.exe returns:
msLoadMap(): Image handling error. Unable to initialize image
msCalculateScale(): General error message. invalid image extent ....
I get the same results for shp2img on the working shapefile/map file.
THE FOLLOWING WORKS:
MAP
IMAGETYPE AGG
SIZE 256 256
TRANSPARENT ON
PROJECTION
"init=epsg:4326"
END
OUTPUTFORMAT
NAME 'AGG'
DRIVER AGG/PNG
IMAGEMODE RGB
END #Outputformat
LAYER
NAME TxCounties
DATA co48_d00
STATUS ON
TYPE Polygon
CLASS
NAME "classTxCounties"
STYLE
COLOR 0 255 0
OPACITY 25
OUTLINECOLOR 0 0 0
WIDTH 2
END #style
END #class
END #layer
END #Map
Anyone have any idea's why this might not work in the first case? Or what else can I do to debug the problem?
Kent
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100119/d119d3f8/attachment.html
