[mapserver-users] resolution
Alan Boudreault
aboudreault at mapgears.com
Mon Jan 25 13:36:02 EST 2010
What do you mean by "I still in 72 dpi". How do you check your image DPI ?
Alan
On January 25, 2010 01:24:18 pm Valeria Muñoz wrote:
> ok, i update mapserver version to 5.6, i change my mapfile, but I still in
> 72 dpi...
> mapfile
> MAP
> NAME neonline_mapa
> RESOLUTION 300
> DEFRESOLUTION 72
> SIZE 1667 1667
> UNITS dd
> SHAPEPATH "c:/ms4w/Apache/htdocs/test_mapfile/data2/"
> EXTENT -112.888238 -57.06133625 -7.419488000000001 13.25116375
> FONTSET "c:/ms4w/Apache/htdocs/test_map_dis/fonts/fonts.txt"
> PROJECTION
> 'proj=longlat'
> 'ellps=WGS84'
> 'datum=WGS84'
> 'no_defs'
> END
> # Background color for the map canvas -- change as desired
> IMAGECOLOR 122 206 232
> IMAGETYPE pdf
> OUTPUTFORMAT
> NAME png
> DRIVER "AGG/PNG"
> MIMETYPE 'image/png'
> IMAGEMODE RGB
> EXTENSION "png"
> FORMATOPTION "TRANSPARENT=ON"
> FORMATOPTION "INTERLACE=ON"
> FORMATOPTION "QUANTIZE_COLORS=256"
> END
> # Legend
> LEGEND
> IMAGECOLOR 255 255 255
> STATUS ON
> KEYSIZE 18 12
> LABEL
> TYPE BITMAP
> SIZE MEDIUM
> COLOR 0 0 89
> END
> END
> 2010/1/25 Jeff McKenna <jmckenna at gatewaygeomatics.com>
> > Alan Boudreault wrote:
> >> Sorry, I was sure you was trying to use the new feature included in
> >> MapServer 5.6. In MS <5.6, you can't really do more that setting the
> >> resolution to 300.
> > If you are using MS4W 3.0, you can extract the "MapServer version 5.6.0
> > release Upgrade" package on the MS4W downloads page [1], to install
> > MapServer 5.6.0
> > If you have questions about performing this upgrade, please use the MS4W
> > email list[2].
> > [1] http://www.maptools.org/ms4w/index.phtml?page=downloads.html
> > [2] http://lists.maptools.org/mailman/listinfo/ms4w-users
> > -jeff
> > Jeff McKenna
> > FOSS4G Consulting and Training Services
> > http://www.gatewaygeomatics.com/
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
Alan Boudreault
Mapgears
http://www.mapgears.com
