[mapserver-users] Re: mapserver grib example
windfreak martijnvanderpauw at gmail.com
Tue Jan 26 09:12:40 EST 2010
Hi Jeff,
That's something I try to investigate. I know mapserver is installed with
GDAL ( mapserv -v tells me that) but I can't find gdalinfo on our (Linux)
system. Another reason I know GDAL should be installed is that I am able to
present geoTIFF with our mapserver.
Kind regards,
Martijn
2010/1/26 Jeff McKenna [via OSGeo.org] <
ml-node+4460747-1994709429 at n2.nabble.com<ml-node%2B4460747-1994709429 at n2.nabble.com>
> windfreak wrote:
> > Hi,
> > I already found the pages you note. But, unfortunately it doesn't help me
> on
> > the Grib - Mapserver integration. I can't find good documentation on
> that.
> > Right now I keep getting errors like '/maps/test.grb is not an EPPL file'
> Have you verified that your local MapServer/GDAL build supports that
> format?  You can execute 'gdalinfo --formats' to see a list of the
> drivers that are supported on your local build.
> -jeff
> Jeff McKenna
> FOSS4G Consulting and Training Services
> http://www.gatewaygeomatics.com/
> [hidden email]<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=4460747&i=0>
>  View message @
> http://n2.nabble.com/mapserver-grib-example-tp4439271p4460747.html
> To unsubscribe from Re: mapserver grib example, click here< (link removed) ==>.
-http://www.topspots.org         the best windsurfspots
-http://www.weer.nl                 the site I work at with work
View this message in context: http://n2.nabble.com/mapserver-grib-example-tp4439271p4460811.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100126/6c767207/attachment.html
