[mapserver-users] Re: mapserver 5.4.2 Reprojection error
tommaso
tommasodb at googlemail.com
Tue Jan 26 11:46:35 EST 2010
Hallo,
> I am not sure if this helps in your case, but you can try to edit the
> "epsg" file in the projection library and add +towgs84=0,0,0 in the
> line that defines the <31467> projection. EPSG:3067 needs this extra
> parameter for sure and I believe it is the same with your next try
> with EPGS:32632. Let's hope it cures 31467 as well.
> -Jukka Rahkonen-
Thanks a lot! this worked with 31467.
With 32632 I not yet sure, if it worked. I'll made some more tests.
> Do you have a different URL. This one is pointing to localhost.
I'm very sorry but our application is not (yet) reachable from
internet.
Thanks again,
tom
> Aihe: [mapserver-users] mapserver 5.4.2 Reprojection error
> Hallo list,
> With mapserver 5.4.2 (FGS API 9.5) , if my map is reprojected
> in EPGS:31467, it is shifted about 100 m to north and 50 m to
> east (approximately).
> The same data with the same mapfile and the same URL works
> fine on mapserver 5.0.2 (FGS API 1.0.0).
> The data are stored in an Postgis Database with srid 4326.
> The URL I'm using is:
> http://localhost:8081/cgi-bin/map?request=getMap&version=1.1.1&srs=EPSG:31467&bgcolor=000000&transparent=true&exception=application/vnd.ogc.se_inimage&layers=messe_background,halls&width=1600&height=1600&bbox=3553126.5489076,5796728.52646645,3556663.71956136,5800882.49936431&format=agg
> On the linked picture you can see the same map with the same
> bbox generated by the two version of mapserver. The map on the
> right is to north-east shifted, the map on the left is ok.
> http://img695.imageshack.us/img695/9590/cebit.png
> If the map is not reprojected (EPGS:4326) there are not
> errors.
> Did somebody observe the same issue?
> Thanks,
> Tom
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100126/c8cd95cc/attachment.html
