[mapserver-users] Fatal error: Call to undefined function (dl)
Murat Beyhan
beyhan at deprem.gov.tr
Wed Jan 27 06:01:55 EST 2010
Hi Friends,
I have installed apache 2.2.14 and php 5.3.1
then I have installed mapserver 5.6.1 with phpMapScript module.
I have try to open a phpmapscript file on the server, which was worked
fine for php4, but the following message occured
Fatal error: Call to undefined function dl()
in /usr/local/httpd/htdocs/zone/zone30.php on line 3
line 3 in my php file is as follows
dl('php_mapscript.so');
so
I have enabled first dl on the php.ini file
than still this problem couldn't solved and I read php manuals and dl
function was deprecated so I removed that line but this time I faced the
following error
Fatal error: Call to undefined function ms_GetVersion() in
IT seems php_mapscript module could not install properly...
When I try to use phpinfo_mapscript.phtml
also same problem occured.
in httpd.conf file php loaded and other php pages works fine except than
php mapscript
LoadModule php5_module modules/libphp5.so
so I have created a directory under php directory named extensions where
I installed than I put php_mapscript.so into there. Than I write the
path into php.ini file as follows
extension_dir = "/usr/local/httpd/php/extensions"
but still could not open phpmapscript files on the server.
Could you help me please
Murat
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
