[mapserver-users] Re: WMSGetFeatureInfo problem (No results, using OL)
Steve.Toutant at inspq.qc.ca Steve.Toutant at inspq.qc.ca
Wed Jan 27 09:19:50 EST 2010
Stela,
In that example you are querying layers Test1 and Test2.
Below you defined your control with layer _test
It is confusing...
You should try with a simpler example. I suggest you create a mapfile with
one layer (don't forget the tolerance and template), create the wms layer
in Openlayer and define the control on this layer only.
Steve
Steve Toutant, M. Sc.
Analyste en géomatique
Secteur environnement
Direction de la santé environnementale et de la toxicologie
Institut national de santé publique du Québec
945, avenue Wolfe
Québec, Qc G1V 5B3
Tél.: (418) 650-5115 #5281
Fax.: (418) 654-3144
steve.toutant at inspq.qc.ca
http://www.inspq.qc.ca
stela anders <stelaanders at gmail.com>@lists.osgeo.org
Envoyé par : mapserver-users-bounces at lists.osgeo.org
27/01/2010 08:35 AM
A
"Fawcett, David (MPCA)" <David.Fawcett at state.mn.us>
cc
MapserverList OSGEO <mapserver-users at lists.osgeo.org>
Objet
Re: [mapserver-users] Re: WMSGetFeatureInfo problem (No results, using OL)
Hi David!
The url is :
http://localhost/cgi-bin/mapserv.exe?map=map.map&&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetFeatureInfo&LAYERS=Test1,Test2&QUERY_LAYERS=Test1,Test2&STYLES=,&BBOX=-65.806807%2C-16.885911%2C-38.978193%2C-11.238939&FEATURE_COUNT=10&HEIGHT=257&WIDTH=1221&FORMAT=image%2Fpng&INFO_FORMAT=text%2Fhtml&SRS=EPSG%3A4326&X=366&Y=217
Executing that URL direct in browser generate that:
Content-type: application/vnd.ogc.se_xml
Thanks
Stella
2010/1/26 Fawcett, David (MPCA) <David.Fawcett at state.mn.us>
Stella,
What does the getFeatureInfo call look like?
Use Firebug to find the URL used to make the request and post it here.?
David.
From: mapserver-users-bounces at lists.osgeo.org [mailto:
mapserver-users-bounces at lists.osgeo.org] On Behalf Of stela anders
Sent: Tuesday, January 26, 2010 1:33 PM
To: MapserverList OSGEO
Subject: [mapserver-users] Re: WMSGetFeatureInfo problem (No results,
using OL)
Any idea whats happening?
I lost all day trying to fix that, but got nothing :(
Stella
2010/1/25 stela anders <stelaanders at gmail.com>
Hello guys...
My mapfile:
  PROJECTION
        "+init=epsg:4326"
    END
    WEB
        IMAGEPATH 'C:\temp\'
        IMAGEURL '/tmp/'
        QUERYFORMAT text/html
        METADATA
            "wms_title"     "WMS Server"
            "wms_onlineresource" "http://localhost/cgi-bin/mapserv.exe?"
            "wms_srs"       "EPSG:4326 EPSG:42304 EPSG:42101 EPSG:4269"
            'wms_feature_info_mime_type' "text/html"
        END
    END
   QUERYMAP
        COLOR 255 0 0
        SIZE -1 -1
        STATUS OFF
        STYLE hilite
    END
LAYER
       METADATA
            "wms_title"    "Test"   ##required
             "wms_include_items" "all"
             "wms_feature_info_mime_type" "text/html"
        END
        TYPE POINT
        STATUS ON
        INCLUDE "Connection.map"
        DATA "the_geom from viwtest USING UNIQUE oid USING SRID=0"
        PROJECTION
            "+init=epsg:4326"
        END
        TOLERANCE 5
         HEADER   "header.html"
        TEMPLATE "template.html"
         FOOTER   "footer.html"
Templates:
Header.html
<!-- MapServer Template -->
<html>
  <head>
    <title>MapServer Template Sample</title>
  </head>
Template.html
<body>
    <b>OID:</b> [oid]
  </body>
Footer.html
</html>
WMSGetFeatureInfo  Javascript (OpenLayer)
var infoCtl = new OpenLayers.Control.WMSGetFeatureInfo({
                    layers: [_test],
                    title: 'Click on the map to get information on
layers',
                    queryVisible: true,
                    infoFormat: 'text/html'
                infoCtl.events.register("getfeatureinfo",map,showInfo);
 function showInfo(evt) {
            alert(evt.text);
I´m getting that :
<html>
  <head>
  </head> Content-type: application/vnd.ogc.se_xml
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
<!DOCTYPE ServiceExceptionReport SYSTEM "
http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
<ServiceExceptionReport version="1.1.1">
<ServiceException>
</ServiceException>
</ServiceExceptionReport>
Stella
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100127/d4fa89cc/attachment-0001.html
