[mapserver-users] Repeating annotation, using LABEL_NO_CLIP=1
with Open Layers
Fawcett, David (MPCA)
David.Fawcett at state.mn.us
Wed Jan 27 09:51:15 EST 2010
Ted,
If you go the tile route, each image request to MapServer is independent, so it will get a copyright notice.
You can go use an OpenLayers Layer.WMS layer with singleTile set to True and a ratio of 1 to get one tile that only fills the viewport. (This is similar to the deprecated OpenLayers.Layer.WMS.Untiled). http://dev.openlayers.org/releases/OpenLayers-2.8/examples/notile.html
The only issue with ratio of 1 is that you see the white background when you pan.
I think that the best solution would be to add an attribution layer using OpenLayers. http://openlayers.org/dev/examples/attribution.html
David.
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Bob Basques
Sent: Tuesday, January 26, 2010 7:20 PM
To: Ted Spradley; mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Repeating annotation, using LABEL_NO_CLIP=1 with Open Layers
It probably still there, only out of frame if you are using OpenLayers,
which I believe grabs a tile larger than the current view for panning by
the user.
Other than adding another layer or restricting the tiles retrieved to
the same size as the current view port, I don't know of a way of getting
a copyright into view. There may be some OpenLayers settings that aloow
for a center tile that is as large as the current view with tiles
arouand the edges, but this may be a performance hit.
bobb
On 1/26/2010 5:51 PM, Ted Spradley wrote:
> Hi everyone,
> I recently added a copyright notice via an annotation layer. When the
> mapfile is accessed as a WMS
> via OpenLayers, the annotation repeats on every tile. I am using the
> directive:
> PROCESSING 'LABEL_NO_CLIP=1'
> Setting the OL WMS call to Untiled did cause the annotation to disappear
> altogether. Any thoughts?
> Thank you!
> Ted S.
> /* The layer */
> LAYER
> NAME "copyright"
> STATUS ON
> TYPE annotation
> TRANSFORM ll #set the image origin to be lower left
> FEATURE
> POINTS
> 100 -20 #set the offset from lower left position in pixels
> END
> TEXT "copyright text" #this is your displaying text
> END
> CLASS
> LABEL #defines the font, colors etc. of the text
> FONT "ARIAL"
> TYPE TRUETYPE
> SIZE 8
> BUFFER 1
> COLOR 0 0 0
> BACKGROUNDCOLOR 255 255 255
> END
> END
> UNITS PIXELS #sets the units for the feature object
> END
> Thank you,
> Ted S
> MapServer version 5.6.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV
> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
> SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS
> INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> Linux/Fedora7
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
