[mapserver-users] SV: Projection and mapquery
Morten Sickel
Morten.Sickel at nrpa.no
Thu Jan 28 14:38:35 EST 2010
Sorry, forgot to say
mapserver version 5.2.2 from osgeo4w php 5.2.5 if that matters
Morten
________________________________________
Fra: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org] på vegne av Morten Sickel [Morten.Sickel at nrpa.no]
Sendt: 28. januar 2010 19:37
Til: mapserver-users at lists.osgeo.org
Emne: [mapserver-users] Projection and mapquery
I presently have a set up in which I plot some measurements on some background maps. Things work fine, but I want to add the possibility to query the measurement data set by clicking on a measurement. The measurements have coordinates in lat lon and I only manage to query those data if I plot the entire map in the same projection. I have tried to reproject the query point using code like
$mapproj=$map->getProjection();
$layerproj=$map->getlayerbyname('mobil')->getProjection();
if($mapproj!=$layerproj){
$mapproj=ms_newProjectionObj($mapproj);
$layerproj=ms_newProjectionObj($layerproj);
debug(array($geopoint->x,$geopoint->y));
$geopoint->project($mapproj, $layerproj);
// projects the point from the projection of the map to the projection of layer
the debug function just dumps the data and it is clear that the point is correctly reprojected, but anyhow
$map->queryByPoint($geopoint, MS_MULTIPLE, 1);
never gives anything if the mobil-layer and the map are in different projections.
Are there any ways to overcome this? As I am mostly working on maps from 60 deg north and upwards, geographical projection is not the projection of choise and I would prefer not having to reproject the measurement data.
M._______________________________________________
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
