[mapserver-users] How to serve individual RAW binary Bands from
WCS as floating point geotiff
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Thu Jan 28 16:34:54 EST 2010
How have you defined the OUTPUTFORMAT for GEOTIFF_FLOAT?
-Jukka Rahkonen-
Peter Willis wrote:
> Hello,
> I have been setting up a WCS map file for mapserver.
> PROBLEM:
> Problems arise when rasters are defined
> as follows:
LAYER
NAME SomeDataChannel120
STATUS OFF
DEBUG ON
TYPE RASTER ### required
PROCESSING "BANDS=120"
METADATA
"wcs_label" "Data/stuff"
"wcs_rangeset_name" 'bands'
"wcs_rangeset_label" "Stuff thats mapped"
"ows_extent" '-135 55 -121 46'
"wcs_resolution" '0.08333333333333332 -0.083333333333333332'
"ows_srs" 'EPSG:4326'
"wcs_srs" 'EPSG:4326'
"wcs_formats" 'GEOTIFF_FLOAT,GEOTIFF_INT16'
"wcs_nativeformat" 'ENVI'
# "wcs_bandcount" '563'
"wcs_rangeset_axes" 'bands'
END
DATA /data/stuff.img
PROJECTION
"init=epsg:4623"
END
DUMP TRUE ### required
END
I have 'wcs_bandcount' commented out because mapserver
causes an internal error in the web server if I define the
band count.
I get floating point geotiff served with the following client request:
http://sparky.com/cgi-bin/wcs?REQUEST=GetCoverage&SERVICE=WCS&VERSION=1.0.0&COVERAGE=SomeDataChannel120&CRS=EPSG:4326&BBOX=-135,55,-121,46&WIDTH=432&HEIGHT=216&FORMAT=GEOTIFF_FLOAT&RangeSubset=contents:nearest[Band[120]]
..however, I always only get the first band from the img file....
QUESTIONS:
Is there a problem with this setup?
Do I need to define each band as a layer in the mapfile
or will mapserver WCS allow the client to request a single
channel?
Thanks for any enlightenment,
Peter
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
