[mapserver-users] Re: Help PHP mapscript. DrawQuery with extent=shapes
Pedroaa pedroaa10 at gmail.com
Fri Jan 29 08:57:02 EST 2010
Thanks for your answer, but what i need is draw a map with
the resultant extent of one query.
Mapserver CGI, do it very easy. Doing parameter extent=shapes, i get a map
with extent of all layers queried.
In PHP mapscript, until now, to set resultant extent in mapfile extent and
can draw a map with zoom to resultant objects, i go thru all layers and go
thru every resultant shape and then i build an extent comparing all
extents........ puffff (it's very complicated!!!)
Pedro
2010/1/29 Alan Boudreault [via OSGeo.org] <
ml-node+4479866-283922663 at n2.nabble.com<ml-node%2B4479866-283922663 at n2.nabble.com>
> Hi Predroaa,
> To simulate this CGI request, you could use:
>  * the OwsrequestObj class
>  * the function Layer->queryByShape()
> Alan
> On January 29, 2010 07:34:09 am Pedroaa wrote:
> > Hi friends, my english is not so good (im from argentina).
> > I need do a $oMap->drawQuery(), but i need do it like Mapserver CGI.
> /cgi-bin/mapserv?mode=nquery&imgext=-60.70866644902204+-31.64842730088904+-
> > 60.70265555972983+-31.644427300889028&
> > -> mapext=shapes  <-
> &imgxy=367+133&imgbox=367+133+473+249&imgsize=829+552&layers=departamentos
> > Do you know if there is any way to do that easily using phpmapscript?
> > thanks
> > Pedro.
> Alan Boudreault
> Mapgears
> http://www.mapgears.com
> [hidden email]<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=4479866&i=0>
>  View message @
> http://n2.nabble.com/Help-PHP-mapscript-DrawQuery-with-extent-shapes-tp4479709p4479866.html
> To unsubscribe from Help PHP mapscript. DrawQuery with extent=shapes, click
> here< (link removed) >.
View this message in context: http://n2.nabble.com/Help-PHP-mapscript-DrawQuery-with-extent-shapes-tp4479709p4480065.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100129/e68f12ba/attachment.html
