[mapserver-users] mapserver 5.4.2 Reprojection error
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Fri Jan 29 12:47:31 EST 2010
I believe it is basically this issue:
http://trac.osgeo.org/proj/ticket/11
So it is known already. Make a comment on a ticket and add some pressure, perhaps some day it will be corrected.
-Jukka-
-----Alkuperäinen viesti-----
Lähettäjä: mapserver-users-bounces at lists.osgeo.org puolesta: tommaso
Lähetetty: pe 29.1.2010 18:37
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: Re: [mapserver-users] mapserver 5.4.2 Reprojection error
On Tue, 2010-01-26 at 15:13 +0200, Rahkonen Jukka wrote:
> Hi,
> I am not sure if this helps in your case, but you can try to edit the
> "epsg" file in the projection library and add +towgs84=0,0,0 in the
> line that defines the <31467> projection. EPSG:3067 needs this extra
> parameter for sure and I believe it is the same with your next try
> with EPGS:32632. Let's hope it cures 31467 as well.
> -Jukka Rahkonen-
It seems to work with both EPGS:31467 and EPGS:32632, thanks again.
Is it a bug in Mapserver, it isn't ? should I report a bug?
greets,
Tom
