[mapserver-users] New to mapserver; question about USGS
DRG/GeoTIFF files
Roger André
randre at gmail.com
Fri Jan 29 16:16:08 EST 2010
Hi Jon,
You don't appear to have any projection info in your map file. Since you
have "UNITS dd" in it, I assume you want to display the map in lat/lon
WGS84? If so, your MAP file needs an entry that looks like this:
PROJECTION
"init=epsg:4326"
END
and your usgs LAYER (the name should be quoted btw) should have the UTM
projection defined in it, like this:
LAYER
NAME "usgs"
PROJECTION "init=epsg:26719" END
Best of luck,
Roger
On Fri, Jan 29, 2010 at 4:38 AM, Jon Miner <cp_n18 at yahoo.com> wrote:
> Hi -
> I'm new to Mapserver, and so far impressed by it's capabilities. I've
> installed the FGS package via
> fgs-mapserver_basic_5.6.0-fgs_9.5-linux-i386.bin and played with their demo
> program.
> I'm having a problem with a USGS DRG file that is encoded as a GeoTIFF
> file. It doesn't display on the webpage, and I'm not sure where to start
> debugging this. I've checked the file with gdalinfo:
> Driver: GTiff/GeoTIFF
> Files: o43071a4.tif
> Size is 5388, 6854
> Coordinate System is:
> PROJCS["NAD27 / UTM zone 19N",
> GEOGCS["NAD27",
> DATUM["North_American_Datum_1927",
> SPHEROID["Clarke 1866",6378206.4,294.9786982138982,
> AUTHORITY["EPSG","7008"]],
> AUTHORITY["EPSG","6267"]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433],
> AUTHORITY["EPSG","4267"]],
> PROJECTION["Transverse_Mercator"],
> PARAMETER["latitude_of_origin",0],
> PARAMETER["central_meridian",-69],
> PARAMETER["scale_factor",0.9996],
> PARAMETER["false_easting",500000],
> PARAMETER["false_northing",0],
> UNIT["metre",1,
> AUTHORITY["EPSG","9001"]],
> AUTHORITY["EPSG","26719"]]
> Origin = (295125.999493999988772,4778305.842659999616444)
> Pixel Size = (2.438400000000000,-2.438400000000000)
> Metadata:
> AREA_OR_POINT=Area
> TIFFTAG_IMAGEDESCRIPTION=USGS GeoTIFF DRG 1:24000 Quad of Manchester
> North. Product:522644
> TIFFTAG_SOFTWARE=USGS CD Archiver program tif2usgsdrg v.1.0
> TIFFTAG_DATETIME=1997:01:10 07:16:28
> TIFFTAG_XRESOLUTION=72
> TIFFTAG_YRESOLUTION=72
> TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
> Image Structure Metadata:
> COMPRESSION=PACKBITS
> INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left ( 295125.999, 4778305.843) ( 71d31'7.66"W, 43d 7'54.16"N)
> Lower Left ( 295125.999, 4761593.049) ( 71d30'45.52"W, 42d58'52.88"N)
> Upper Right ( 308264.099, 4778305.843) ( 71d21'26.67"W, 43d 8'6.54"N)
> Lower Right ( 308264.099, 4761593.049) ( 71d21'5.95"W, 42d59'5.20"N)
> Center ( 301695.049, 4769949.446) ( 71d26'6.44"W, 43d 3'29.80"N)
> Band 1 Block=5388x1 Type=Byte, ColorInterp=Palette
> Color Table (RGB with 256 entries)
> 0: 0,0,0,255
> 1: 255,255,255,255
> 2: 0,151,164,255
> 3: 203,0,23,255
> 4: 131,66,37,255
> 5: 201,234,157,255
> 6: 137,51,128,255
> 7: 255,234,0,255
> 8: 167,226,226,255
> 9: 255,184,184,255
> 10: 218,179,214,255
> 11: 209,209,209,255
> 12: 207,164,142,255
> (etc...)
> And my map file looks like this:
> MAP
> NAME DEMO
> STATUS ON
> SIZE 400 300
> SYMBOLSET ../etc/symbols.sym
> EXTENT -72 42 -71 44
> UNITS dd
> SCALEDENOM 24000
> SHAPEPATH "../data"
> IMAGECOLOR 255 255 255
> FONTSET ../etc/fonts.txt
> CONFIG "MS_ERRORFILE" "/tmp/ms_error.txt"
> # Start of web interface definition
> WEB
> MINSCALEDENOM 24000
> MAXSCALEDENOM 24000
> # On Windows systems, /tmp and /opt/fgs/tmp/ms_tmp/ should be created at
> the root
> # of the drive where the .MAP file resides.
> IMAGEPATH "/opt/fgs/tmp/ms_tmp/"
> IMAGEURL "/ms_tmp/"
> LOG "/tmp/gmap.log"
> END
> LAYER
> NAME usgs
> METADATA
> "DESCRIPTION" "USGS GeoTIFF"
> END
> TYPE RASTER
> STATUS ON
> DATA o43071a4.tif
> END
> END # Map File
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100129/8f3ac356/attachment.html
