[mapserver-users] Need help testing WMS segfault
Paul Ramsey pramsey at opengeo.org
Fri Jan 29 16:38:09 EST 2010
Roger,
It looks like you're on Linux, so pull a stacktrace, it's fun!
gdb /path/to/mapserv
... lots of info ...
(gdb) run "QUERY_STRING=map=/var/www/mapfiles/seattle.map&layers=roads&styles=&service=WMS&width=256&format=image/png&request=GetMap&height=256&srs=EPSG:4326&version=1.1.1&bbox=-122.338256836,47.6586914062,-122.332763672,47.6641845703"
then when you hit to segfault, do
(gdb) bt
bt stands for backtrace
now you'll have a lot more useful information about what went wrong,
Yours,
Paul
On Fri, Jan 29, 2010 at 1:27 PM, Roger André <randre at gmail.com> wrote:
> Hi All,
> I'm experiencing some strange behavior that I would appreciate some help
> testing.  My MapServer 5.6 instance is segfaulting in response to certain
> WMS requests it is receiving from TileCache.  Below is one of the specific
> requests:
> http://localhost/cgi-bin/mapserv?map=/var/www/mapfiles/seattle.map&layers=roads&styles=&service=WMS&width=256&format=image/png&request=GetMap&height=256&srs=EPSG:4326&version=1.1.1&bbox=-122.338256836,47.6586914062,-122.332763672,47.6641845703
> I'd appreciate it if someone who has a layer that covers Seattle would try
> the bbox extents listed above and report back if it causes an error for
> them.
> FYI - When I set this bbox as the EXTENTS in my MAP, and the SIZE to 256
> 256, Mapserver delivers the image without any problem.
> Thanks,
> Roger
> mapserver-users at lists.osgeo.org
