[mapserver-users] How to serve individual RAW binary Bands fromWCS as floating point geotiff
Peter Willis pwillis at aslenv.com
Fri Jan 29 18:11:14 EST 2010
Hello,
Thanks. I have the following line in the map file LAYER declaration:
PROCESSING "BANDS=120"
In any case, the current configuration gives me a floating point geotiff
that is all zeros. I know that band 120 of the file has non-zero double
precision data in it.
Maybe it's a byte ordering problem....
Peter
Lime, Steve D (DNR) wrote:
> Is this link of help?
>   http://mapserver.org/input/raster.html#special-processing-directives
> There's a directive to extract a single band from an n-band image...
> Steve
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Peter Willis
> Sent: Friday, January 29, 2010 10:41 AM
> To: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] How to serve individual RAW binary Bands fromWCS as floating point geotiff
> Hello,
> Interesting... The documentation indicates:
> &RangeSubset=contents:nearest[Band[120]]
> I tried what you suggest but continue to have the same problem.
> The mapserver *did not* complain about '&RESAMPLE=BILINEAR&Band=120'
> so I guess we can assume that those parameters work.
> Peter
> Rahkonen Jukka wrote:
>> Hi,
>> I have never used this myself: &RangeSubset=contents:nearest[Band[120]]
>> Is that WCS 1.0.0 parameter?  For selecting bands from WCS 1.0.0 service I have been using something like
>> &RESAMPLE=BILINEAR&Band=4
>> -Jukka Rahkonen-
>> -----Alkuperäinen viesti-----
>> Lähettäjä: mapserver-users-bounces at lists.osgeo.org puolesta: Peter Willis
>> Lähetetty: pe 29.1.2010 0:26
>> Vastaanottaja: mapserver-users at lists.osgeo.org
>> Aihe: Re: [mapserver-users] How to serve individual RAW binary Bands fromWCS as floating point geotiff
>> Hello,
>> The definition of GEOTIFF_FLOAT is as follows:
>> OUTPUTFORMAT
>>    NAME GEOTIFF_FLOAT
>>    DRIVER "GDAL/GTiff"
>>    MIMETYPE "application/octet-stream"
>>    IMAGEMODE FLOAT32
>> END
>> I Added the MIMETYPE as shown to ensure that web browsers
>> would ask to save the file rather than just open it in an
>> image viewer from a temp file. (MS Windows...)
>> That part works fine.
>> Mostly I am concerned with extracting a specific 'band'
>> from the multi-band file. The server serves floating point
>> geotiff just fine.
>> Peter
>>> Hi,
>>> How have you defined the OUTPUTFORMAT for GEOTIFF_FLOAT?
>>> -Jukka Rahkonen-
>>> Peter Willis wrote:
>>>> Hello,
>>>> I have been setting up a WCS map file for mapserver.
>>>> PROBLEM:
>>>> Problems arise when rasters are defined
>>>> as follows:
>>> LAYER
>>>    NAME SomeDataChannel120
>>>    STATUS OFF
>>>    DEBUG ON
>>>    TYPE RASTER ### required
>>>    METADATA
>>>      "wcs_label"           "Data/stuff"
>>>      "wcs_rangeset_name"   'bands'
>>>      "wcs_rangeset_label"  "Stuff thats mapped"
>>>      "ows_extent" '-135 55 -121 46'
>>>      "wcs_resolution" '0.08333333333333332 -0.083333333333333332'
>>>      "ows_srs" 'EPSG:4326'
>>>      "wcs_srs" 'EPSG:4326'
>>>      "wcs_formats" 'GEOTIFF_FLOAT,GEOTIFF_INT16'
>>>      "wcs_nativeformat" 'ENVI'
>>> #    "wcs_bandcount" '563'
>>>      "wcs_rangeset_axes" 'bands'
>>>    END
>>>    DATA /data/stuff.img
>>>    PROJECTION
>>>      "init=epsg:4623"
>>>    END
>>>    DUMP TRUE ### required
>>> END
>>> I have  'wcs_bandcount'  commented out because mapserver
>>> causes an internal error in the web server if I define the
>>> band count.
>>> I get floating point geotiff served with the following client request:
>>> http://sparky.com/cgi-bin/wcs?REQUEST=GetCoverage&SERVICE=WCS&VERSION=1.0.0&COVERAGE=SomeDataChannel120&CRS=EPSG:4326&BBOX=-135,55,-121,46&WIDTH=432&HEIGHT=216&FORMAT=GEOTIFF_FLOAT&RangeSubset=contents:nearest[Band[120]]
>>> ..however, I always only get the first band from the img file....
>>> QUESTIONS:
>>> Is there a problem with this setup?
>>> Do I need to define each band as a layer in the mapfile
>>> or will mapserver WCS allow the client to request a single
>>> channel?
>>> Thanks for any enlightenment,
>>> Peter
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
