[mapserver-users] TIme support on mapserver 5.6.3, it's working?
Alexander Petkov
greenkov at gmail.com
Thu Jul 1 15:09:38 EDT 2010
On Thu, Jul 1, 2010 at 6:27 AM, rai 8 <max1000 at gmail.com> wrote:
> Hello,
> I've been working with mapserver to get a map with time support, time
> parameter, I followed the tutorial in documetation
> http://mapserver.org/ogc/wms_time.html and this post
> http://osgeo-org.1803224.n2.nabble.com/Accessing-images-using-time-dimension-td1991324.html#a1991324
> and I can't run the mapserver to change the image with a time parameter.
> I test several configurations but any works, the last is the same like the
> post in the maillist, this is what i've done:
> in a postgis database
> create table satellite (image_path text, image_time timestamp);
> select AddGeometryColumn('satellite', 'the_geom', 4326, 'POLYGON', 2);
> insert into satellite (image_path, image_time, the_geom)
> values ('/home/vbox/Downloads/animacio/sat1.tif', '2007-05-11 10:00Z',
> GeomFromText('POLYGON((-31.82 75.55, -31.82 26.5, 51.31 26.5,51.31 75.55,
> -31.82 75.55))', 4326));
> values ('/home/vbox/Downloads/animacio/sat2.tif', '2007-05-11 11:00Z',
> and the map file:
> LAYER
> NAME "time_w"
> TYPE POLYGON
> STATUS ON
> CONNECTIONTYPE POSTGIS
> CONNECTION "dbname=tile_index host=127.0.0.1 user=postgres
> password=xxxxxx"
> DATA "the_geom from satellite using unique oid using srid = 4326"
> METADATA
> "wms_title" "time_index_w"
> "wms_srs" "EPSG:4326"
> "wms_timeextent" "2007-01-01/2007-12-31"
> "wms_timedefault" "2007-05-11T11:00:00Z"
> "wms_timeitem" "image_time" #a column in postgis table of type
> END
> END
> LAYER
> NAME "sat_w"
> STATUS ON
> TYPE RASTER
> METADATA
> "wms_title" "Satellite"
> END
> PROJECTION
> "init=epsg:4326"
> END
> TILEINDEX "time_w" # Layer name containing time index
> TILEITEM "image_path" # DB column containing path to image
> END
> anyone finds some error?
> thanks
The time-related metadata items:
need to be in the METADATA section of the "sat_w" layer.
Alex
